Fender Flares
Old Feb 17, 2006 | 11:51 PM
alc235's Avatar
alc235
Fender Flares
I am interested in adding oem fender flares to a stock 99 Explorer XLT. Ive seen what I thought were 2000 model explorers with factory flares and I am wondering if these just easily bolt up or what? Can I add just the flares without adding any other pieces of trim around the truck to make it match? Thanks for any help!
Old Feb 22, 2006 | 01:11 AM
alc235's Avatar
alc235
Um...........
Old Feb 22, 2006 | 11:57 AM
97FORDXLT's Avatar
97FORDXLT
you can add the flares, but you can only add them if you take your running board off, or if it came stock with no running boards. you may have to paint the plares the same color of your explorer depending on how you want it. Here is a web site with some things for your truck, i dont know if they have your fender flares, but other sites will. http://www.suvxccessory.com/xccessor...-explorer.html Good luck
Old Feb 22, 2006 | 03:30 PM
mab6680's Avatar
mab6680
i have a 2000 xls with grey flares that are not painted but the xlt has painted flares i dont know about the running board thing i have factory nerf bars and the flares are about two inches from the bars but any way there just held on with sheet metal srews and them stupid clips that always break when you try to take them out hope this helps
Old Mar 8, 2006 | 07:41 PM
mrwrench's Avatar
mrwrench
you have to drill the fenders and quarter panel to install the flares , also you have to put the runnig board EB or limited style.
Other option is pu the 99 flares and step board (tube)
the problem is how it will look without 16" wheels
