Pre or post turbo pyrometer
Old Feb 17, 2006 | 08:47 PM
jsmahan's Avatar
jsmahan
I have the Autometer phantom series and am trying to figure out if its calibrated for pre or post. The instructions sent with it described placing the probe in the down pipe. When I called Autometer, they advised it was for pre turbo. I used the post placement due to d/pipe already having bung for probe. W/ my mods as described in signature and chip setting on 75, here are my average numbers. Unloaded - cruise 600-700 5-7 psi boost, hard acceleration 750-850 21-22psi. Loaded w/ 11,500 5ver - cruise 700-800 8-10psi, up hill pull maintaining 65-70mph 900-1100 20-25psi. How do these numbers compare to those of you with similar mods w/ pre turbo pyro?
Old Feb 17, 2006 | 09:03 PM
guzzle92's Avatar
guzzle92
Some pyros have color coded guage faces that are different for pre vs. post turbo and are just shifted down the temperature scale. Post-turbo temps will read 200º-300º below pre-turbo. So instead of a 1250º max, you need to try and keep them below 950º-1000º. A pyro only measures temps.. 1000º pre is 1000º post, the exhaust just cools down by the time it hits the downpipe.
Old Feb 17, 2006 | 09:08 PM
amish77's Avatar
amish77
pre is generally considered more accurate, but if it breaks for any reason you're gonna fry your turbo.
Old Feb 17, 2006 | 09:40 PM
jsmahan's Avatar
jsmahan
Guzzle, are you pre or post. If pre what temps are you seeing w/ the chip?
Old Feb 17, 2006 | 10:09 PM
guzzle92's Avatar
guzzle92
My pyro is pre. With the 4" exhaust, I can get it close to 1250º with my foot into it HARD on 50hp, empty. I won't know what it'll do with the 5er pullin hard till this summer. Looking at -8º F right now, not good camping weather!
Old Feb 17, 2006 | 10:37 PM
SuperDutyF250's Avatar
SuperDutyF250
Its getting cold around here, were about 1 degree cooler in Fort Collins.
Old Feb 18, 2006 | 12:05 AM
jtharvey's Avatar
jtharvey
Those sound a like they're a little higher than mine -- I'm post turbo too, but only for another week or two. Cruising at 75, Mine sits 500-600, and rarely see's 700. I don't regularly pull that much weight, but I typically pull around 6000lbs and only once last summer did my temps hit even 900. That was going up a very long hill, in the dead heat of August. My typical cruising temps pulling the trailer are 600-700. But that was with a Predator on the tow/haul tune. I'll have to see if they are different this summer now that I have a DP chip installed instead.
Be very, very careful at anything over 1000, post turbo. You're in serious risk of some very expensive damage in that range. If it gets that high, back off the go pedal a little. It's not worth risking a $10K engine for 5-10 mph up a hill.
