Water in fuel??- Need Help
Old Feb 17, 2006 | 06:07 PM
Justforfishing's Avatar
Justforfishing
the water in fuel light has come on my truck recently. I drained the HCFM but this didn't seem to help much. The weird thing is the light will often go off for a little while and then comes back on. I heard something about a bad censor and a TSb to fix it. Is there a TSB on the sensor or do i most likely have water in the fuel? If so do I fix this by changing the filters? Thanks
Old Feb 17, 2006 | 08:27 PM
usroute66's Avatar
usroute66
Some WIF sensors have been going bad at the primary fuel filter. Take it back to the dealer. I believe there is a TSB on the issue.
Old Feb 17, 2006 | 09:17 PM
Justforfishing
ok- i will do that.....as soon as I take the Edge off. Is there a charge to fix this???
Old Feb 18, 2006 | 12:39 AM
c-bolt's Avatar
c-bolt
check this out also, it could have something to do with it
http://www.forddoctorsdts.com/photographs/index2.php
second pic down on the right side.
later
Joe
