HELP! Carb problems
Old Apr 11, 2001 | 12:33 PM
magnus's Avatar
magnus
HELP! Carb problems
Old May 4, 2001 | 08:47 PM
oft's Avatar
oft
HELP! Carb problems
Hi all,
I dropped a 351W in my 78 with dual 2 1\2 inch pipes, factory 4bbl intake manifold and a rebuilt My buddy rebuilt it) 4 bbl holley 600 CFM carb.
Started it up and it runs like crap. Barely idles and will hardly take a load (ie dies if I put it in gear). Timing is about where it should be. We pulled the plugs and they are wet (gas). Gas is also coming out the tail pipe. My buddy leaned out the jets to no avail. I have taken the carb off and readjusted the floats but I don't think they were bad enough to make the engine run this bad. Could the jets be bad? they're 48's.
Help! a new carb costs about $200 and i'd like to avoud that if I could.
Jay
Old May 4, 2001 | 11:32 PM
MSTRAWN's Avatar
MSTRAWN
HELP! Carb problems
Sounds like a bad power valve in the holley. Mike.
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals
MSD6
Whiter whites/Brighter brights
Old May 5, 2001 | 12:11 AM
oft's Avatar
oft
HELP! Carb problems
What does the power valve do?
Jay
Old May 5, 2001 | 02:21 AM
hilander's Avatar
hilander
HELP! Carb problems
Maybe the float. Is it set too high?
SHOCKLEY MOTORSPORTS
"If you didn't build it, it ain't yours"
Old May 5, 2001 | 03:05 PM
proeliator's Avatar
proeliator
HELP! Carb problems
I'd vote for the power valve too. Its opens up under load for flow and if its blown it will be shooting way too much gas through your carb at idle.
If your knuckles ain't bleeding you did something wrong.
'72 F-250 "Hi-Boy" 4x4, Dana 60/HD44, FE428 @ 400 ponies , 4-speed, custom suspension w lift, mud on black.
Old May 6, 2001 | 12:46 AM
oft's Avatar
oft
HELP! Carb problems
You were right. Replaced the power valve (it was blown) and the truck ran great... for about 3 minutes. The floats were set too high. so tomorrow I'm going to try to reset them. I pray to god it runs good after this.
Thanks for the help!
Jayson
Old May 7, 2001 | 07:42 AM
dzjammer's Avatar
dzjammer
HELP! Carb problems
Another power valve note, if you ever backfire through the carb, it could blow the power valve again. The new Holley street avengers have a check valve to prevent this. There also is a kit to add a valve to your old Holley.
Dave,
79 F-150 4x4, 390 w/C6, Edelbrock carb, 33X12.50 never will be finished.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
