Rear-End help
Old Feb 17, 2006 | 02:43 PM
55FordLover's Avatar
55FordLover
Rear-End help
Gentlemen,
I have found a 9" donor for about $175 out of a 73 Ford Truck....now can i transfer the shoes and wheel cylinders from a 1954 ford f100 to this rear-end? Kind of new at this and don't want to jack it up....just had my original rear end done with new lines, cylinders and shoes...and that was about $125 there....also the bolt pattern is 5-5 i believe....there are not 5 by 4-1/2....so this also means i need to get rims....is there any way easier to get better highway gears then switching out the dana 44 rear-end.....my numbers on the original rear-end
are 1068818 or B198981 USPA1 10bolt....hopefully someone here can decipher this for me and tell me what I have as gears...also what kind of splines do I have........HELP!!!!!!
James
also found 121B3 2169 on the long tube side of the rear-end
