Running board brackets 1953 Needed
Old Feb 17, 2006 | 02:41 PM
Crazydan's Avatar
Crazydan
Question Running board brackets 1953 Needed
Anybody have or know where I can get a set of running board front brackets for my 1953 F 100? Right and left sides, the back two brackets are not needed. Thanks to all for the help.
Crazy D
Old Feb 17, 2006 | 08:38 PM
grncoup's Avatar
grncoup
are you going to be running a stock gas tank? what about mounting the battery? the reason i ask is i have a set (all four) of custom mounts that came with my tci frame that i won't be using. these mounts won't work with a stock tank or battery in the stock location.
Old Feb 17, 2006 | 11:20 PM
Crazydan's Avatar
Crazydan
My battery is now located under the hood, and the gas tank is now relocated at the rear frame. Will your brackets work with the stock frame and running boards? If so, do you have pics you can send me, and how much are you asking?
