1978 - 1996 Big Bronco
mileage help
Old Feb 16, 2006 | 07:59 PM
BondoFord's Avatar
BondoFord
Unhappy mileage help
alright heres the deall im in highschool currently jobless (but looking) and im bout outa cash i drive a 1988 bronco 302 aod n any help i can get to increase my mpg or even plausible ideas to earn cash in the mean time till i can get a job would be appreciated
oh any btw it has a small oil leak i believ from the valvcover gaskets so im running som thicker oil in it and i know how it will suck down you mpg a little bit
Old Feb 16, 2006 | 09:51 PM
tdwhiteIII's Avatar
tdwhiteIII
Ignition
I understand your trying to save money but you could put out alittle money for new ignition sys.
I put a msd ignition box and new thicker wires 10mm
and the msd blaster coil in one of my trucks and it get on average 3-6 mpg better plus idles perfect and smogs pefectly.
Drawback is new plugs a little more often.
I have 201000 on that truck and 4x4 the hell out of it.
But I am glad for the nignition system and it is easy to install.
Old Feb 16, 2006 | 10:10 PM
WhëëlMå1's Avatar
WhëëlMå1
Well what are you getting for mileage now? That will let us know if we CAN help you.
Old Feb 17, 2006 | 12:07 AM
aurgathor's Avatar
aurgathor
As Rich said, post your current mpg and other vital stats like lift, tires, mods, etc. However, even if you're getting around 16 - 18, that's still expensive nowadays if you don't have a job. IMHO, your best bet is to drive your Bronco only if it's absolutely necessary, or get a job that can pay for the gasoline, and a little more.
Old Feb 17, 2006 | 09:13 AM
lbianc1's Avatar
lbianc1
Buy a moped!
If you are trying to pinch pennies and save on MPG, you are driving the wrong truck. The best my 89 ever got was 14mpg. That aint too good especially with current gas prices. If you are in a bind and can't afford gas, I wouldn't spend the money to try and improve gas mileage cause you still aint gonna be that good regardless.
Old Feb 17, 2006 | 07:43 PM
aurgathor's Avatar
aurgathor
And those improvements are not cheap at all -- one would need to drive quite a bit for them to pay in savings on gas.
Old Feb 18, 2006 | 09:56 AM
BondoFord's Avatar
BondoFord
i am not really sure my exact milage 32" tires mess it up a lil but i believe its gettinh 8-10 mpg sorry for taking so long to reply
Old Feb 18, 2006 | 10:02 AM
WhëëlMå1's Avatar
WhëëlMå1
Well how about throwing some cheap stock sized tires on it? Big Tires + 302 =
edit for your edit: 32" isnt that big. When was the last tuneup you had? Fuel system treatment?
Old Feb 18, 2006 | 10:11 AM
WhëëlMå1's Avatar
WhëëlMå1
How much thicker is the oil you are running?
Old Feb 18, 2006 | 10:25 AM
wozxxx86's Avatar
wozxxx86
u can tighten the valve covers down, altho tricky causesa the upper intake. as far as mpg. for elchepo, whats ur exaust? like. to get a lil bit better flow outta stock cut the muff off. make sure ur timing is set correctly. new plugs wires and disty cap will help a good deal. then worry about ur intake. i run sae 30 in my 5.0 with 230k milage on it i can get 16.5.
Old Feb 18, 2006 | 10:38 AM
BondoFord's Avatar
BondoFord
i run hd40 when its warm enough but at the moment i believe i got 20/50 in it right now i put som efuel teartment in last week n replaces the plugs, cap , and the roter (didnt have the $ for the wires)n as far as exause it is stock without the muffler
Old Feb 18, 2006 | 11:21 AM
MBBFord's Avatar
MBBFord
The cheapest ways to save would be to make sure your tires are inflated to recomended specs, accelerate slow, you don't have to be the first person off the line from a red light.
I look like a old man when I drive, but I don't care, with gas prices not going under $2.20 for about a year now, you have to do something.
I can get 16mpg out of my 77 F-100 with a 302, 31" tires, 3.50 gears in town, driveing like a grand pa.
Old Feb 18, 2006 | 09:19 PM
aurgathor's Avatar
aurgathor
20W50 oil?!? I'd fix the valve cover gaskets as the oil is way too heavy. Unless the engine is on it's last leg, 15W40 should be the heaviest oil to use, but 10W30 or maybe 10W40 is what most people should be using. IMHO, a 32" tire with stock gearing could be one of the main reason behind your miserable mpg. And you may have an off-road tread, which makes things worse.
Old Feb 18, 2006 | 11:01 PM
rudedogii's Avatar
rudedogii
Mileage?
I think alot of you guys are getting pretty good MPG, considering you drive Broncos. The Bronco isn't known for the good mileage.
I have a 95 with 35inch Goodyears and 4:56 gears. My average Mileage is about 10MPG, last summer I was coming back from a trip to Moab Utah and my MPG was 8MPG. It was 10 going and 8 coming back. I had the motor checked out and it turned out to be a bad O2 senser. Thats alot of gas to go from SoCal to Utah and back? But Moab is well worth the trip!
Old Feb 28, 2006 | 09:20 PM
thenewjohndeere's Avatar
thenewjohndeere
Heres what i would do ... hitch a ride with friends on the weekday and drive it on the weekends. I mean we all know that you have the sweetest truck at school ... so drive the guys around on the weekend w/ the top off and let them drive you durring the week. B/c you know and i know that most of them have there dads gas card. Or find you a rich girl
