Ontario Chapter Join Chapter>, Leader: loudfords
Now I know......
Old Feb 16, 2006 | 07:12 PM
kwboom's Avatar
kwboom
Now I know......
Now I know what thoes tools we have in the garage is really used for.......
got this from another site I go to everyday.......
For all the other people who build stuff, or are just starting to. This list the *real* purpose of all the tools the snap-on guy would tell you.
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly painted part you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprint whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been s searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog
**** off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style paper-and-tin oil cans and splash oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last overtightened 58 years ago by someone, and neatly rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a
50¢ part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
EXPLETIVE: A balm, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
Snap Ring Pliers: A tool typically used to remove or install circular clips from shafts and bores and launch them across the shop or into a gravel driveway.
Grease Gun: A device used unsuccessfully to force grease into rusty, plugged up grease fittings. When not in use this device meters a steady drip of oil onto the surface beneath it and mysteriously weeps a coat of grease onto its outer surface, no matter how thoughly it was cleaned before it was put away.
Old Feb 16, 2006 | 09:31 PM
taisa899's Avatar
taisa899
those are exact desriptions of everything. As I was reading them I was thinking to myself been there done that!
Jim
Old Feb 17, 2006 | 02:10 PM
fp_5's Avatar
fp_5
Well done!
I've also done most of those and a few more.
Old Feb 17, 2006 | 08:29 PM
Fomoko1's Avatar
Fomoko1
I might as well confess to some of these deeds too.
Old Feb 17, 2006 | 09:12 PM
Dealford's Avatar
Dealford
Looks like the one on C.T. dot org.
Remember that the beauty of a tool is only in the eye of the beer holder.
AL.
Old Feb 18, 2006 | 10:37 AM
kwboom's Avatar
kwboom
ahhhhhhhhh BEER the only tool for a sucessfull repair..
Old Feb 18, 2006 | 06:51 PM
Green Wreck's Avatar
Green Wreck
Ha ha ha thats so true. i work at an auto wreckers and all that stuff applies to me like every day
Old Feb 19, 2006 | 09:05 AM
cdncowboy's Avatar
cdncowboy
lol I have used all of those for those uses
Old Mar 7, 2006 | 01:41 PM
CowboyPenner's Avatar
CowboyPenner
I'm cut and pasted it so I can send it to my dad. He'll get a kick outta of it, as did I.
bnovak
22
Sep 25, 2016 10:40 AM
ProStreetDriver
General Automotive Discussion
Jun 18, 2016 11:48 AM
banjopicker66
24
Apr 8, 2013 11:49 AM
PhL0aTeR
Aug 26, 2011 10:13 PM
Fordenthusiasts
Garage & Workshop
36
Apr 22, 2008 04:47 PM
