check engine light
Old Feb 16, 2006 | 05:51 PM
weaseljosh's Avatar
weaseljosh
check engine light
the last couple days my 03 powerstroke 7.3L will be running fine than the check engine light will come on. i can hear the engine running but i can't accelerate. then in about ten seconds or so it will be just fine. it's happened a couple of times here and there, but today it happened three times back to back. any help would be awesome, thanks.
Old Feb 16, 2006 | 08:33 PM
mech2161's Avatar
mech2161
Sounds like the TPS throttle position sensor. It is replaced as a pedal assembly. Have the codes scaned to make sure.
Old Feb 17, 2006 | 10:03 AM
ofstrey's Avatar
ofstrey
Have you had to replace your CPS yet? That may be another possibility if you're running with the original OEM sensor.
