8.8 Rear Rebuild Qs (95 F-150)
95 F-150, 351w, 4x4 Supercab, 3.55 8.8, 153k. Rear pinion bearing is bad. Not sure yet about the condition of the pinion and ring gear. It has a lot of play and makes a howling noise - unfortunately it had been mistaken for tire noise (and ignored) for at least the last 3k miles. We use this truck just for towing on short/medium length trips.
I figure the cheapest way to get back on the road is a bearings-and-seals rebuild and replace the pinion/ring only if they are damaged.
1) Anyone have good links or tips on the rebuild job? It's damn hard to search for "8.8".
2) Are the procedures for Mustang 8.8s similar? Are any parts interchangeable with the F-150s 8.8?
3) What else would be good to do while 'in there'? I kind of want to go a 4.10 ratio, but that means changing the front too - sounds like a budget-breaker.
Dave
Dave
Yeah, I decided I'm gonna skip the ratio change and not touch the front.
I also found some good sources for how-to info:
http://www.angelfire.com/theforce/5o...5ohtech001.htm
https://www.ford-trucks.com/article/...ear_Setup.html
http://www.badshoeproductions.com/products.html
Dave
Dave
86f150step
02-14-2017 01:55 PM
Ron94150
08-28-2015 09:35 PM
