can someone help me out? I am having trouble getting my front blinkers to work on my 1978 F-150 4x4. I have changed the flasher, checked all fuses, and even swapped out the wiring harness to try and eliminate the problem. I get a signal to the rear on both sides both nothing to the front. All side marker lights work and the headlights operate fine. I am also having trouble getting the instrument lights to work. All inquiries are appreciated
Use a test light and check for power at the front blinker. Also make sure the ground wire for each blinker has a clean tight connection to ground. There is a good tech article about testing/ repairing blinkers, might want to read it.
