another wiper question
washer and cruise don't work. The fuses are good. Does anyone know if there is a possibility that if the wiper interval governer is bad, the washer and cruise and horn won't work also? I thought it might be the clockspring, but that seems only to control the air bag. I could use help with this one. Thanks.
washer, wiper interval pot both on stalk loom electrical plug, pull of steering wheel and covers from upper steering column and check that electrical circuit plugs are seated in combination stalk switch....do you have hi/low beam selection?
probably failed combination stalk switch....washer switch and interval pot usually first to fail...abt $55 from FTE site sponsors RockAuto and others
