Aerostar Ford Aerostar
Towing W/aerostar
Old Feb 15, 2006 | 03:03 PM
SHAGWAG's Avatar
SHAGWAG
Towing W/aerostar
Has Anyone Towed A Bass Boat With An Aerostar. What Type Of Shocks Do You Reccomend? Can I Get A Hitch W/out Removing The Spare Tire? Thanks ****
Old Feb 15, 2006 | 03:23 PM
VanGo's Avatar
VanGo
I tow a 26' sailboat with my Ext. XLT. I have a Valley brand hitch that retains the spare. My Aero has Monroe Sensatrac shocks. They work fine. A rear sway bar might be nice.
Old Feb 15, 2006 | 03:32 PM
Bear River's Avatar
Bear River
Former ******
For towing, a rear sway bar is almost a must have. Good shocks are recommended. Monroe Sensotracs seem to be what most people are useing to overcome the vans wobble and leaning issues.
Old Feb 15, 2006 | 05:43 PM
aerocolorado's Avatar
aerocolorado
Of all various options tried over the past years, air-lift rear shocks were the best overall addition for towing needs. I had a set of Gabriel Hi-Jackers that were simple to install and provided that extra lift for heavily loaded passenger travel or towing needs. A small, inexpensive 12v compressor will fit nicely in the rear storage well where you can also locate the inflation valve.
Old Feb 15, 2006 | 06:05 PM
ken1mod's Avatar
ken1mod
I agree with and did exactly the same as aerocolorado. It is not quite as nice as being able to control from the dash but works great. I spliced a pressure gauge into the air circuit.
Ken
Old Feb 15, 2006 | 07:43 PM
cbr900's Avatar
cbr900
I tow a 20ft searay with mine plus a three bike motorcycle trailer here in florida. Like Ken and AERO I fitted the air-lift rear shocks on mine plus tha anti-sway bar and it handles great when towing. I did nothing to the tranny though because I saw a large tranny cooler up front of the rad I don't think it is a standard extra cooler as I have seen them and there much smaller than the one I have and I have never had any over heating problems with the tranny.
Old Feb 15, 2006 | 08:13 PM
VanGo's Avatar
VanGo
What's the tongue weight on your bass boat trailer? Mine is 200lbs and the Aero rides level with the Sensatracs. I only tow less than 1% of the time, the rest of the time I get the smooth Sensatrac ride.
There's also variable rate springs. It all depends on your application which way to go.
Old Feb 15, 2006 | 10:39 PM
93nighthawk's Avatar
93nighthawk
You picked the perfect van for towing.
Sense you have an EXT then you don't have to worry about relocating the spare. Everything else about the suspension has been said.
Old Feb 16, 2006 | 05:13 AM
pauldfixr's Avatar
pauldfixr
I bolted a "Quality-S" hitch on my '94 AWD EXT and apart from having to pull up the carpet and carefully drill through the floor and box rails underneath, it went in pretty easy. When I got the van the spare and hardware were already gone - probably eaten by salt here years ago. I bough it on Ebay for about $130 including shipping, and it's a class IV with 2" receiver. Since I haven't done any serious or distance towing yet, I've not done all the other suggested mods yet... but it's good to know that the van should pull my 17' bowrider nicely once I have it set up properly!
Old Feb 16, 2006 | 09:04 AM
SHAGWAG's Avatar
SHAGWAG
Thanks Guys. It Sounds Like A Rear Sway Bar And Sensotracs Might Be Best For Me. I Don't Tow A Whole Lot With Two Young Kids At Home. Hopefully That Will Change As The Kids Get Older. Does Air Shocks Have Stiff Ride? My Boat Is A 18ft Astro W/ 150hp So It Should Have Similar Tongue Weight As Vango.
Old Feb 16, 2006 | 09:14 AM
96_4wdr's Avatar
96_4wdr
also consider suspension air bags in rear springs, I've been towing and mountain roading with air lift bags for 6 years, work great...tow 3,500 lb trailer
got tired of forking out $100 bucks every two years for expensive air lift shocks, shock portion wears out and are worthless
...found a low cost source for Tokico shocks, so run those now...far better shock than Gabriel or Monroe
can make air lift shocks and air lift bag suspension almost like original ride or raise higher and firmer than the hemorroids can stand
Old Feb 16, 2006 | 09:36 AM
SHAGWAG's Avatar
SHAGWAG
Who Manufactures Rear Air Bags? Where Can I Get Tokico Shocks? Thanks!
Old Feb 16, 2006 | 09:55 AM
aerocolorado
Here's a link to an earlier discussion regarding air lifts: <a href="https://www.ford-trucks.com/forums/archive/index.php/t-397299-Thinking%20Air-Lift%20Inserts%3F%20-%20Think%20Again">Thinking Air-Lift Inserts? - Think Again</a>
Old Feb 16, 2006 | 10:34 AM
SHAGWAG's Avatar
SHAGWAG
Thanks Aero It Is Good To See All Sides Before Making My Decision.
Old Feb 16, 2006 | 10:31 PM
puman's Avatar
puman
Pulled about a 4800 pound t/t (loaded weight), half way across the country and back many times. Sensatrac worked just fine for me. Got my hitch from the local U Haul dealer. Get this. It had a U Haul sticker over a Draw Tite sticker......and was $30 cheaper than a Draw Tite. Sway bar is a no brainer and with this much weight a leveling hitch is a must also.
