93 Ex Ford Vehicle Security System
Old Feb 15, 2006 | 10:28 AM
uh60james's Avatar
uh60james
As I was changing the brake light switch today I saw a box labeled Ford Vehicle Security System with antenna wire hanging from it. I have owned the vehicle for less than a month and the previous owner told me of a button that must be pressed to start the vehicle, there is also a red LED I assume both are part of the security system. Does anyone know if remotes are still available for this system as I got none with the vehicle also will the dealership have to program them or can they be self programmed. I did not see a model no. on the box but maybe I was looking in the wrong place. There is also a battery behind the glove box which I assume is for the system too. Thanks!
Old Feb 16, 2006 | 06:30 PM
uh60james's Avatar
uh60james
On my 02 explorer if I had one remote I could program another, If nobody can answer anything else does this apply to the older systems or does it just have adjustable switches inside the remote?
Old Feb 19, 2006 | 05:31 PM
uh60james's Avatar
uh60james
Ok, well hopefully someone can help me with this than. I found a website where I can buy an oe or aftermarket remote for a 93 explorer. However the remotes offered only have 3 buttons lock, unlock and panic. Looking at the module it appears there is also an alarm as there is a shock sensor connector and pin 2 on the accessory connector is for a siren. Would the lock button arm the alarm or should there be another button if there is an alarm?
