Offroad & 4x4
Will this lift combo work?
Old Feb 15, 2006 | 08:03 AM
mr_malina's Avatar
mr_malina
I have a 1991 F150 2WD. My intentions are as follows: Purchase Rough Country 6" lift - "Kit includes front coil springs, radius arm drop brackets, I-beam drop brackets, power steering pitman arm, 4 Heckethorn 8000 series shocks, u-bolts, and rear blocks." I would also buy extended brake lines. I would like to run 35's, truck is mainly a daily driver with some towing. I already know I would have to regear. Also I have the 8.8 rear axle, will that hold up?
Old Feb 15, 2006 | 08:26 AM
s8whiskey's Avatar
s8whiskey
Yea the 8.8 max is about 35's you can push 38's on there just no hard core stuff. You could get by with 3.73 but I would get the 4.10 just for the fact of towing.
The SnoMan's Avatar
The SnoMan
As long as you do not use a after market locker, it will hold up fine (LSD's are okay) You want a 4.56 to 4.88 for towing minimum hear with 4.88 being better is load weighs more than a few thousand pounds.
Old Feb 15, 2006 | 08:28 AM
The SnoMan's Avatar
The SnoMan
4.10 for towing would be a joke with 35's as that is about that same as a 3.55 with stock tires and that is not a good tow gear before you even factor extra drag for tires and lift. People are hung up and 4.10 being great gears even for big tires.
Old Feb 15, 2006 | 08:29 AM
s8whiskey's Avatar
s8whiskey
Just a quicky queston not a highjack. When would you ever use 5.54 gears?
Old Feb 15, 2006 | 09:15 AM
mr_malina's Avatar
mr_malina
Should I expect any problems down the road with that lift kit. I plan on keeping this truck many many years. Honesltly the whole point of this is for a better stance.
Old Feb 15, 2006 | 09:19 AM
s8whiskey's Avatar
s8whiskey
The only thing I would change on that kit is add a leaf instead of blocks in the rear and you will keep that truck a long time. Just keep her well maintaned and she will never give a big problem we all have hicups though
Old Feb 15, 2006 | 10:24 AM
The SnoMan's Avatar
The SnoMan
With some 44's or so. Better have a beefy rear axle though to handle the axle and housing strain from them.
Old Feb 15, 2006 | 10:26 AM
The SnoMan's Avatar
The SnoMan
I agree, better traction because of reduce spring torque wrapup the blocks can aggrevate
Old Feb 15, 2006 | 11:06 AM
mr_malina's Avatar
mr_malina
The blocks are 6", will a add a leaf give that much lift?
Old Feb 15, 2006 | 12:05 PM
my79f's Avatar
my79f
if the blocks are six inchs you could probably get away with doing a shackle flip and add-a-leaf, and that would be pretty close.
Old Feb 15, 2006 | 12:31 PM
mr_malina's Avatar
mr_malina
Explain this shackle flip.
Old Feb 15, 2006 | 09:38 PM
Jack-USAF's Avatar
Jack-USAF
hey i just installed a 6" rough country lift on my 88 f150 with 35" tires. it came with everything for the front and came with both blocks and add a leafs. check out my gallery. i have 355 gearing and yeah i lost some power but seriously its not bad. i can still spin all 4 wheels in the mud and on the street i still spin the rears. eventually i will get gears but as of now i am happy. and it is a daily driver.
Old Feb 15, 2006 | 09:49 PM
fishmanndotcom's Avatar
fishmanndotcom
SEARCH
good grief, i can't count how many times we have gone through a shackle flip. i got pics in my gallery for the reading impaired!
-cutts-
Nick-1973-ford
Sep 12, 2016 09:19 PM
justcruzin125
May 15, 2016 07:37 AM
350z
15
Feb 22, 2016 10:49 PM
hawaiian-style
May 22, 2008 03:38 AM
DANA60
Sep 10, 2004 10:20 PM
