Offroad & 4x4
95 F250 Solid axle swap question
Old Feb 15, 2006 | 08:03 AM
jnye6625's Avatar
jnye6625
I am looking at putting a dana 60 solid front end in my 95 f250 and i have run into a few problems. It is extremely hard for me to find a front axle from a 86-97 f350 which i am told will bolt right in. It is however easy to find an axle from a 78-79 f250 which is also a dana 60. Would it be possible to use one of these instead? Is the steering completely different, or can i use the steering from an f350? Are the spring perches in the same place? If not i have no problem removing the old ones and putting new ones in the right spot if it will work. Has anyone ever done with swap with an axle from a 78 or 79? What about brakes? Will the brake lines on my truck fit on the older calipers? Will the newer style brake calipers work on the older axle? Any input would be greatly appreciated! Thanks!
Old Feb 15, 2006 | 08:31 AM
78f3504x4's Avatar
78f3504x4
If you have a 77.5/79 Dana 60, sell or trade it for a 85.5/91 or 92/97 Dana 60. It will be easier. To use the earlier axle, you will have to make spring mounts that are inward beacuse the early 60 has 32" center-to-center spring pads. The later 60 has 36" pads.
Old Feb 15, 2006 | 08:42 AM
Flareside94's Avatar
Flareside94
If you can get that 78-79 D60 for a good price, get it. Those things are golden. And do as 78 said, use it to trade for a later D60 front with somebody who has a later and needds the older.
Old Feb 15, 2006 | 09:01 AM
jnye6625's Avatar
jnye6625
So if i remove the spring pads on the 78-79 axle and put the new pads at the correct locations, will it work? Is everything else the same? I have this old axle with correct gearing and in excellent condition and would rather use it if possible. Thanks
Old Feb 15, 2006 | 09:04 AM
tjc transport's Avatar
tjc transport
i ain't rite
if i am not mistaken, your 95 has a high pinion axle in it, and the 79 is a low pinion.
Old Feb 15, 2006 | 09:08 AM
s8whiskey's Avatar
s8whiskey
Those can be corrected but thats more work then needed. Like they said he needs to find a some one that can trade him or buy it for him and then find a good 85.5 to 96 1 ton.
Old Feb 15, 2006 | 10:14 AM
jnye6625's Avatar
jnye6625
To tell you the truth its unreasonable to find a f350 axle at a decent price. everyone wants at least 1000 dollars for one. I got this axle for a 78-79 for 100 dollars in great condition. I really want to use this one. The 78-79 axle i have is also high pinion. Does anyone know about switching over the steering? Will the F350 steering bolt onto the knuckles of the 78-79 axle? What about brakes?
Old Feb 15, 2006 | 11:56 AM
tjc transport
i ain't rite
if it is a high pinion D60 with disc brakes, and you are confident of your welding skills, yes, it will work fine after you move the spring perches.
Old Feb 15, 2006 | 12:01 PM
02superstroker's Avatar
02superstroker
02 and up f250 anf f350s also use a dana 60, and have disc brakes. May be a little pricey though... and youd still have to swap spring mounts...
Old Feb 15, 2006 | 12:06 PM
jnye6625's Avatar
jnye6625
sounds good.. the f250 axle has the steering arm on the top of the knuckle at the king pin. Do i need to do anything special to remove this? If i go with the 78-79 axle i dont need it.... i will be putting the f350 steering linkage on it
Old Feb 15, 2006 | 04:34 PM
Flareside94
02 and up Superduty axles are weaker with their sealed unit-bearing hub design. Wanna shell out the cash for the Dynatrac conversion? I know Monsterbaby had a fun time when one of his decided to go out and locked up a tire on his truck. And they're expensive enough that you DON'T want to be replacing them often.
Have you considered going to coil springs with that 78-79 D60? You just shave down the little wedges you buy for hte D44 to accomodate for hte difference in tube size between a D44 and a D60, and weld them on (take them to a professional welder - this is SERIOUS welding!), hook up some coil buckets lower and upper, get some D44 radius arms and extend them, use the coil of your choice, get hte right C-bushings and you're in bushing. Don't forget a trac bar either.
Old Feb 15, 2006 | 05:49 PM
chrono4's Avatar
chrono4
a dana 60 from a 250? was it a snowfighter or somthing?
Old Feb 16, 2006 | 09:03 PM
jnye6625's Avatar
jnye6625
Didnt pretty much all the F250's in 78 and 79 come with a dana 60?
Old Feb 16, 2006 | 09:13 PM
chrono4's Avatar
chrono4
if it was a front 60, it would be a rear 70 then right? is this a 70? https://www.ford-trucks.com/user_gal...&albumid=19344 i dont have the axles here, there at the shop, but i was told that mine from a 78 250 were a 44 and a 60, but are they a 60 and a 70 instead?
Old Feb 17, 2006 | 05:28 PM
threefiftyone's Avatar
threefiftyone
Most F250's came with 44's. The Camper Specials came with 60's, as did the snow plow package. All 1979 F350's came with front 60's.
