352 Knock is back
Old Feb 14, 2006 | 06:53 PM
Redmanbob's Avatar
Redmanbob
352 Knock is back
well it's getting a bit more pronounced now..it makes more noise when in gear (forward) with brake on..if I put it in (N) it cannot be heard from inside truck..but in gear it's a good solid knock..it seems to come from the front left corner..if it's a wrist pin..what are the options? I just dont have $$ / time to mess with it at the moment.
Old Feb 14, 2006 | 07:10 PM
ford390gashog's Avatar
ford390gashog
if its a wrist pin. the damage is big. i had 2 go out in my 360 from the PO using cast iron clips instead of high tensile steel. it dug a 1/4'' groove in the wall until it went into the water jacket.
Old Feb 14, 2006 | 07:15 PM
rusty70f100's Avatar
rusty70f100
Try some heavier oil and take it easy until it can be fixed.
My brother had a wrist pin going out in an old 360 he was running. From what I hear he drove it like that for quite a while, until the affected piston broke a skirt off.
Old Feb 14, 2006 | 07:36 PM
Redmanbob's Avatar
Redmanbob
I need to put a light on it, and see if the knock is top or low end related...I'll try tomorrow..
gashog... on your 352 rebuild what kinda $$ you into before it's done do you think ?
Old Feb 15, 2006 | 02:34 AM
ford390gashog
well i am going for the poor white mans rebuild.
gasket kit + freeze plugs 58.00
rings 60.00
bearings 63.00
valve spring compressor 27.00
ring compressor 11.00
misc 70.00
the heads are still the one big thing i have not tackled. i have decided to skip the FT heads and do something with the C8AE heads.
FxRiZBeAsTLy
Dec 11, 2010 10:45 AM
FxRiZBeAsTLy
Oct 31, 2010 02:53 PM
Cruiseomatic
May 28, 2005 03:40 PM
GammaDriver
18
Aug 14, 2002 08:07 AM
