Hot Start Problems...
Old Feb 6, 2001 | 11:45 AM
proeliator's Avatar
proeliator
Old May 16, 2001 | 02:00 PM
79supercab4x4's Avatar
79supercab4x4
Hey guys, ive been having a wierd problem with my 79 f-150 (400ci) lately. it will start up just fine but after fully heating up, if i turn it off and try to start it again within an hour or so, it turns over EXTREMELY slowly and sometimes not at all. when it does this all i have to do is get a jump start and then it turns over beautifuly. i figured it was the starter and replaced it but it didnt help. i also took apart every wire and cable in the starting system and thuroughly cleaned them, no dice. someone told me they thought it could be the battery, but that didnt really make sense because it always turns over really fast after it's sat and completely cooled down. one thing i noticed is that the starter does get really hot...to the point that i cant keep my fingers on it without getting burned, is this normal? if not, what could be causing this? it used to work just fine and it still has the stock exhaust manifolds and pipes...could it be bad timing or an overly rich or lean condition? any thoughts? thanks in advance for any help.
Old May 16, 2001 | 02:59 PM
easyi812's Avatar
easyi812
Have your battery checked,after the motoUnder a load the battery might be failingr heats up and builds compression the battery may be to weak to turn it over.
Old May 16, 2001 | 10:11 PM
shortbedford's Avatar
shortbedford
hey 79 You need to make sure you have good grounds battery to engine battery to body and engine to body if you have these already make sure they are clean and tight that means taking the cable off the block and cleaning underneath it also msake sure your timing is right too much advance will cause some of this worn timing chain ect.
Old May 17, 2001 | 02:54 AM
karljay's Avatar
karljay
[font size="1" color="#FF0000"]LAST EDITED ON 17-May-01 AT 03:56 AM (EST)[/font][p]The starter might be heat soaked, I'd get a starter blanket from ThermoTec and/or make a steel shield to protect it from the exhaust heat. I use both the steel shield and the starter blanket but I have header that run close to the starter. I'd also confirm the timming, too advance makes it hard to start, then I'd check the temp of the ground wires and check for proper ground.
Use a digital guage to check for a voltage drop and proper ground.
I've also heard that a weak battery will kill a starter, make sure the battery has enough power, I like the 850~900 cca ones myself.
Old May 19, 2001 | 12:19 AM
79supercab4x4
well guys, i feel retarded now. it did end up to be the battery. i guess that just goes to show that a bad battery can give problems in all kinds of strange ways.
Old May 19, 2001 | 07:21 AM
jowilker's Avatar
jowilker
You now join the crowd of us with egg stains on our faces. :-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
