tow capacity
Old Feb 14, 2006 | 06:26 PM
blockmanjohn's Avatar
blockmanjohn
tow capacity
I'm trying to find out the maximum towing capacity for my '95 F150. It has the 5 liter V8, 4x4, manual transmision. I lost the owner's manual so there is no help there. Is it printed somewhere on the truck?
Old Feb 14, 2006 | 06:43 PM
dgeesaman's Avatar
dgeesaman
Right on the door pillar.
However, I would not approach that number if you are in a hilly area, doing very long drives, or towing horses or livestock or other cargo with a high center of gravity or a shifty nature. In that case I would limit to 75% of the sticker limit.
Dave
Old Feb 14, 2006 | 06:44 PM
ford390gashog's Avatar
ford390gashog
the tow rating is not on the door pillar just the GCWR is.
Old Feb 14, 2006 | 07:13 PM
dgeesaman's Avatar
dgeesaman
Rats, you're right. I'd check my owners manual (I have a 95 4x4 w/ auto), but it's at the shop today for balljoints. IIRC, the limit for the manual tranny is around 5500-6000lb. Definitely find out what that limit is before towing anything near that limit. If you still can't find it send me a PM and I'll look it up when I get my truck back later this week.
Dave
Old Feb 14, 2006 | 08:49 PM
Mark Wenner's Avatar
Mark Wenner
Tow ratings are very low for the M5OD-equipped trucks, around 3000lb give-or-take depending on your actual GCWR and assuming you have 3.55 gears. If you happen to be one of the few with 4.10s the rating goes up to about 5000 or so.
Old Feb 14, 2006 | 08:52 PM
ford390gashog
mark is correct. that truck if it has a M5OD is good for about 3k nothing more.
Old Feb 16, 2006 | 06:42 AM
dgeesaman's Avatar
dgeesaman
I have my 95 manual here.
For the Regular Cab F-150, Manual Tranny, 5.0L, 4x4, the rear ratio is 3.55, the GCWR is 7800lb, and trailer weight range is 0-3500lb.
For the Supercab F-150, Manual Tranny, 5.0L, 4x4, the rear ratio is 3.55, the GCWR is 7800lb, and trailer weight range is 0-3100lb.
Dave
Old Feb 17, 2006 | 12:29 AM
dhag911's Avatar
dhag911
what about the automatics (E4OD)
Old Feb 17, 2006 | 07:23 AM
dgeesaman's Avatar
dgeesaman
Post the cab type, axle ratio, engine, 4x4/2x4, and I'll look it up.
Dave
Old Feb 17, 2006 | 08:20 AM
s8whiskey's Avatar
s8whiskey
If you are in a hilly area and are amking some good hauls please install a tranny temp gauge and dont be doing soem insane stuff. but if its hilly then no more then 3K or you will be looking for a new tranny.
Old Feb 17, 2006 | 10:59 AM
stresssolutions's Avatar
stresssolutions
Limited to the quality of your hitch and brakes. Most bumpers are not rated for much.
Old Feb 17, 2006 | 11:51 AM
d_stange's Avatar
d_stange
I was just going to post a forum about how much i can pull. I have an 88 F150 with a 5.0L and a manual 5 speed. I wanted to buy a gooseneck trailer so i can haul hay. I would be pulling about 11000lbs. Is this a good idea?
Old Feb 17, 2006 | 12:34 PM
stresssolutions
I should have included the clutch in my last post...I knew a company that had a Mitsubishi pickup (this was in 1988) and a semi. The semi died on the road and they used the Mitsubishi to tug it onto the shoulder. Dumb, really, because it took out the clutch.
Got to keep in mind too, that an F150 won't be properly sprung for towing a lot. Brakes, Brakes and more trailer brakes.
Old Feb 17, 2006 | 02:35 PM
dgeesaman's Avatar
dgeesaman
I hope you're trolling.
The answer is no. Even though a gooseneck puts the weight in a better place than a bumper, the truck won't accelerate or stop.
Dave
