Sponsored by: Real Truck
Power lock problems
Old Feb 14, 2006 | 11:24 AM
csurp's Avatar
csurp
Power lock problems
2002 F350 7.3
My power locks stopped working. the dealer tells me that I need a new security module and a reprogram to the tune of $600. Also the door ajar light is always on, dome light does not come on when door is opened and radio does not turn off when key is turned off and door is opened. Dealer says that these might be related but can't tell until the first problem is fixed. All symtoms started at the same time. Has anyone else had these issues?
Thanks in advance.
Chris
Old Feb 28, 2006 | 08:53 PM
PPrash's Avatar
PPrash
My 2002 has the exact same symtoms. How did you come out on yours?
Old Feb 28, 2006 | 09:59 PM
gcozmo's Avatar
gcozmo
My dad had the same problem with his 02 F250, PSD. They ended up changing the Security module and that cleared up all the problems. The Module doesn't cost but $125.00. The cost is in the Labor. They have to pull out the Radio and the Module is on the firewall behind it. If it has gone completely out, which yours sounds like it has. They will have to down load a new code if you have buttons on your door. If it isn't completely gone they may be able to salvage some of the memory to transfer into the new one. $600.00 sounds alittle high, you might get a price from another dealer. I think my dads bill was somewhere around $300.00. Good Luck, Greg
Old Mar 1, 2006 | 06:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome PPrash to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Mar 1, 2006 | 07:37 AM
csurp's Avatar
csurp
They replaced the module and all is well.
Old Mar 1, 2006 | 01:26 PM
Vijay's Avatar
Vijay
Thumbs up
Good to know everything went smooth, how much did they charge?
