302 to 300 need help
Old Feb 14, 2006 | 08:04 AM
GOTMUD?'s Avatar
GOTMUD?
Im wanting to get rid of my 302 efi for a 300 efi any ideas on how i can go about doing this?
Old Feb 14, 2006 | 08:16 AM
s8whiskey's Avatar
s8whiskey
First find a donor vehical. Or find one with the engine and another with the computer and all the wiring. Its not that hard if you find one with all the stuff you need. Find a donor with a bad trannny or a wreck in the rear for cheap.
Old Feb 14, 2006 | 08:47 AM
GOTMUD?'s Avatar
GOTMUD?
I want to keep my 302 but im having so many problems with it. If i can get the 302 to run right and be steady over and over that would be great.
Old Feb 14, 2006 | 10:45 AM
s8whiskey's Avatar
s8whiskey
What kind of problems are you haveing with it? Like whats it doing? We might be able to walk you through getting her ready for the road again.
Old Feb 14, 2006 | 11:06 AM
andym's Avatar
andym
If you want to ditch the 302, we can help with that. If you need help getting the 302 to run right, we'll help with that too. Swapping the motor out is a lot of work that requires a lot of planning and knowledge. It will almost certainly be easier to get your 302 running right.
Old Feb 14, 2006 | 12:15 PM
earnhardtracer38's Avatar
earnhardtracer38
I agree. I had to replace my 302 with a rebuilt one and that takes a lot of work. You would just think its a matter of disconnecting and rehooking but its not as easy as it sounds. Try to figure out what is wrong with it first before you go swapping engines.
