when i use a ridge reamer do i make sure that there is absolutly no sign of the ridge left even if i get a few metal shavings, or do i quit as soon as i see shavings.... tested on a lawn mower engine today and just wanna know what i am doing here.
As the previous post stated , if you have a ridge it needs a rebore as the cyl has been worn to a taper causing the ridge. To answer your question there should be NO ridge left. If you leave a ridge and put new rings in you run the risk of possibly breaking a ring or ledge/land between the ring grooves on the piston, because the sharp edge of the new ring will hit the ridge. Also you don't want to under cut the ridge, which I suppose will not harm the ring or piston as much as leaving a ridge, as only the leading edge of the ring will overhang the undercut. Pull the engine and rebore it you will be much happier.
how thin of a ridge? anything more than .001 is unacceptable. if its that slight just use a hone. which is what i did on my 352. still in spec and worked well.
I leave a faint hint of the ridge then sneak up on totaly removing it with a hone.
If the bore is standard you can get slightly over sized rings but you''ll want to check your ring gap closely and make sure it's in specs. I usually take an old ring and check the gap at top of the stroke the bottom and middle. I pretty sure they make a .002 and.001 over size ring set. Of course if you have access to a set of bore mics you can check it with out removing the ridge.
Pat
