Tire size?
Old Feb 13, 2006 | 10:14 PM
subnet76's Avatar
subnet76
Tire size?
I was wondering what is the widest tire that will fit under a 95 2wd longbed F-150 It has factory 15inch steel wheels (polished).
Old Feb 13, 2006 | 10:25 PM
amish77's Avatar
amish77
don't know the exact measurement, but I know how to find it.
Take your wheel off, and take a straight edge of metal or wood to go in it's place. Then measure from the backside of your straightedge to the inside of the wheel well and find the first thing that it hits. maybe 1/2'' to 3/4'' spacing from there is the most you can get. Then measure from the back of your straightedge to the outside of the wheelwell. Add these two and that's the widest you can go. Oh, and for the front wheels, you might have to get a bit creative with your straightedge. Make sure to go lock to lock on the steering and measure what it's gonna hit first in either case.
hope it helps
Old Feb 14, 2006 | 03:10 AM
mr_malina's Avatar
mr_malina
I can tell you I have a 1991 F150 2wd with 31x10.5, the only problem I have is if I turn the wheel all the way the tires rub a little on the frame.
Old Feb 14, 2006 | 10:39 PM
subnet76's Avatar
subnet76
I was thinking of going with a 255 70 15, I currently have 235 75 15. Think this would be to wide?
Old Feb 14, 2006 | 11:03 PM
pfogle's Avatar
pfogle
255 70?????? I'd think in a 255 it'd be more like 50 series that would about 8 inches wide.
Old Feb 14, 2006 | 11:09 PM
adamjth23's Avatar
adamjth23
I have 255 70 15's and have no problems whatsoever on 92 f150
Old Feb 15, 2006 | 07:08 AM
mike2112's Avatar
mike2112
I've got 255-70-15 on my '87 F-150 (see my gallery) and they work with no problem. In fact, I had even wider ones on the back, but I didn't like the way they looked - they were more squat than I liked. Still, no problems.
