F350 Yoke question
Old Feb 13, 2006 | 05:58 PM
SpectreZ91's Avatar
SpectreZ91
F350 Yoke question
I'm looking for the part # for a yoke.
From an F350 with a Dana 60 that had a CV front style driveshaft. I need the yoke off the front of the transfer case.
I was told it was a 1330, but that doesn't really help when I try to order it, because I get asked a couple of other questions I don't know the answer to..
I'm sure someone here knows exactly what I'm looking for and say "here is the part # from JBG"
I found one in the junkyard for my bronco, but my neighbor needs one now and I can't find any #'s on it..
Thanx!
Old Feb 13, 2006 | 06:53 PM
Lou Braun's Avatar
Lou Braun
When I swapped in an F-350 CV-joint type driveshaft in my F-250 I had to install a replacement front transfer case yoke. The u-joints on this driveshaft were 1330's so I think it is the same as yours
The part number for the transfer case front yoke was FD E7TZ7B214C (transfer case front yoke). It was purchased through a Ford dealer.
Lou Braun
Old Feb 14, 2006 | 04:13 PM
SpectreZ91's Avatar
SpectreZ91
When you say 1330, Isn't there more then 1 type of 1330 yoke?
Old Feb 14, 2006 | 05:37 PM
Lou Braun's Avatar
Lou Braun
I think the 1330 refers to the u-joint size and not the transfer case yoke itself.
Swapping out the yoke is easy enough. Remove the nut that holds the original yoke in the transfer case while holding onto the original yoke with a substantial wrench. Try not to us the transfer case gears to hold the yoke in place while loosening that nut.
When the nut is removed you will find a washer type seal under it. Make sure that this washer is reinstalled or you will have an oil leak when the new yoke is installed.
Pull the old yoke out and slide in the new one. Install the washer seal and torque the nut down. I seem to remember a torque value of about 150 ft-lbs. This is important enough to look up.
Lou Braun
Old Feb 15, 2006 | 05:33 PM
SpectreZ91's Avatar
SpectreZ91
I've already replaced mine..
My neighbor wants to replace his and wants to make sure he buys the right one.
So I can just tell him to go buy a 1330 yoke and he doesn't need any more information then that?
urbex
Feb 1, 2017 01:20 PM
Will Janoske
Feb 5, 2016 08:22 AM
Rusty_S
18
Nov 7, 2015 07:09 PM
Yzzerdd
Jul 9, 2015 11:00 AM
Mark VII
Nov 19, 2014 09:05 PM
