engine Cleaner
Old Feb 13, 2006 | 04:25 PM
BigDog83's Avatar
BigDog83
engine Cleaner
Does anyone know what is the best or safest engine cleaner stuff on the market. I want to clean the mud and dirt grime off the engine??
Any info would be great!! Thanks, greg
Old Feb 13, 2006 | 07:39 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I would answer, but I honestly have no idea.
I will move it to the Appearance and Dress up forum for you.
Old Feb 15, 2006 | 07:45 AM
NorthPac's Avatar
NorthPac
Warm up engine use citrus cleaner let it soak rinse off then repeat again using a paint brush to make it even cleaner. I don’t recommended using a jet steam of water to clean if you do take it easy on jet steaming water on your electrical system. Best to cover some electrical systems with a plastic bag like the alternator, disturber ….. Try not to get degreaser on the Fan belt/s if you do use a fan belt conditioning meant for the type of fan belt you have.
I would not recommend using SuperClean on engines I have seen superclean take off paint under the hood.
Old Feb 15, 2006 | 09:11 AM
tjc transport's Avatar
tjc transport
i ain't rite
whatever you use, make sure no one sees you do it. there have been quite a few cases in the past few years of people cleaning their engines with gunk and other products, and then letting the waste water and crud drain away. they were seen doing this, and reported to the EPA. the last one that went to court here in jersey ended up with a guilty verdict, and a $10,000 fine, with unspecified cleanup costs. there is one waiting to go to court where it was done in one of them drive thru do it yourself car washes.
Old Feb 17, 2006 | 12:11 PM
MemphisSenior's Avatar
MemphisSenior
I use Simple Green Extreme Clean. Got it at Sam's Club. Just follow the directions and you'll be fine. Since I NEVER take my truck off road, I only use it about every 4 or 5 weeks. You'll have to experiment to see what works for you. BTW it's non-toxic, so should be no problem with the EPA. You might want to check with your states laws just to be sure.
Here's a link to an excellent video on cleaning the engine bay.
http://www.adamspolishes.com/videos/...eels_tires.cfm
Old Feb 17, 2006 | 03:24 PM
PW01's Avatar
PW01
I'll second Simple Green!
Old Feb 17, 2006 | 04:29 PM
BigDog83's Avatar
BigDog83
Thanks for the info, I'm going to try simple green and see how it works out
Old Feb 18, 2006 | 10:10 PM
kenro's Avatar
kenro
Don't get your engine dirty!!!LOL.iI use Mean Green.Works great for tires and wheels.
Old May 10, 2006 | 09:44 PM
squeals99's Avatar
squeals99
the best thing that i have used to far is actually pine sol
works great and makes the whole engine smell like pine trees lol
Old May 14, 2006 | 02:56 PM
Raptor's Avatar
Raptor
I started using WD-40 that I buy by the gallon and pour into a spray bottle. Warm the engine, spray everyithing down, then wash it all off (Quarter car wash project so the gunk doesn't end up in your driveway). It beats any cleaner by far for removing caked up oil, grease & grime, but it's really safe for your engine.
Old May 16, 2006 | 03:22 PM
squeals99's Avatar
squeals99
no offense or anything but i thought on a WD40 warning label it says to keep away from electrical units and engines...
i use pledge or pine sol on all the plastic and gunk on the block area
both look great
Old May 16, 2006 | 11:05 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
I use 3 or 4 layers of opened newspaper under the truck, wash down with paint thinner applied with a engine degreaser gun and compressor. Grease and dirt stay on the paper which acts like a filter, the cement driveway is clean after the thinner evaporates. Granted if dirt is needed to be removed a detergent sprayed on like 409 works better than thinner, pick your weapon.
.....=o&o>.....
Old May 17, 2006 | 01:47 PM
pronstar's Avatar
pronstar
For sure...once it's clean, stay after it and it will stay clean with minilam effort.
Old May 17, 2006 | 04:43 PM
300-6's Avatar
300-6
Oven cleaner work's good on a warn block, but that is all I use it for.
My $.002
Old May 17, 2006 | 04:50 PM
ryaneverk2's Avatar
ryaneverk2
Simple Green
