The wheel will probably fit, but I suspect you will have a problem with the turn signal release. The size where the two meet may be different also. ;-)
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
jowilker, Are you refering to the turn signal "cam"? I have been used to manually putting the signal back to the center after I make a turn. its been that way for the 7 years I have had the truck....do you think it should fit if i took the cam out ??
I didn't get far enough into it to even see the cam like the older trucks have. It is all different in there on the later models. The 76 is basicly the same as the 66, but this 79 hub where the horn, and turn signal met is a different design. The round plate is bigger too.
Hope you find something that works for you.
John
jowilker
66F100s Rule
I looked at the back side of two wheels this afternoon, one 76, one 79 or newer. The newer will fit the shaft but the rim of the wheel and collor of the center are quite different from the other. The newer is much flatter. I wish I had thought to take my digital camera but I didn't.
John
jowilker
66F100s Rule
thanks for checking jw. I can get a pic of this lariat wheel. I has the same shape, contours as the one in my truck. I am not really worried about the rim not looking to par. The one I have now has no horn pad and looks like S%$T
thanks again... heres a pic of
