Carb ?
Old May 24, 2001 | 04:04 PM
bluemustang's Avatar
bluemustang
Carb ?
Will a carb from a 302 work with a 360? The 302 is a 2bbl and the 360 is too. The reason is I have a new carb for a 302 and I need one for my 360 in my 75 F100.
Thanks David
Old May 25, 2001 | 08:35 PM
Like M. Fords's Avatar
Like M. Fords
Carb ?
I know that the bores on a Small Block carb are smaller than on the Big Block carb, but they both are basically the same design, mount, and height. It should work as good if not better at lower speeds, but you will probably loose some passing power at higher speeds. Check your spark plugs after you run it to make sure it is not too lean or rich, and you should be ready to go.
Old May 26, 2001 | 04:38 AM
karljay's Avatar
karljay
Carb ?
