I know there has been much discussion on the subject of transmission swaps, but is there documentation somewhere that will outline the options for what trans can mount to which motor / bellhousing?
I've got a '77 shortbed F100 with a 300-I6 and have been thinking of replacing my 3 speed column shift trans.
Considering my Dana 44 rear end with 3.07 gears, what transmission is a good choice? What can I use, what should I use?
If you want a no frills bullet proof 4 spd then you can go with either a NP 435 or a T-18 or even a T-19. You can put any tranny in if you have the time and money.
