cylinder head pricing question
Old Feb 13, 2006 | 10:05 AM
stumpknockerr's Avatar
stumpknockerr
Red face cylinder head pricing question
howdy everyone! Has anyone ever done business with clearwater cylinder heads
--they have what seems to be a good deal-a completely reworked head for my 351m for $135(each) with free shipping on the core and a core charge of $75
HOWS THAT SOUND? does anyone know of any better deals??? thanks
Old Feb 13, 2006 | 10:11 AM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Feb 13, 2006 | 01:54 PM
grclark351's Avatar
grclark351
that's a pretty low price, but you only get what you pay for. i'd be surprised if there are anything but used factory Ford valves in them, and used factory springs that may or may not "check out". for some circumstances that is fine, but i like to sleep at night. these aren't my pics, but it has happened to me.
http://raceabilene.com/kelly/hotrod/wreck.html
it doesn't have to be a race engine running at redline, mine was completely stock that had just had a "valve job". the head of the valve did a dance on top of the piston, damaged the head and cylinder wall then went south to retire in the muffler. you can get one piece valves on Ebay for a little more than $100.
Old Feb 13, 2006 | 04:39 PM
Matts72's Avatar
Matts72
I have a local friend that does them, starting out at $100 if I buy the parts, this includes all the machining necessary.... Its a pretty good deal, if you are doing any kind of performance, you need to have somebody set your spring heights, you can't get that with a mass rebuilder.
Old Feb 13, 2006 | 08:38 PM
David10's Avatar
David10
Try O'Reilly Auto Parts.
ATK Remanufactured Cylinder Head
Smog - 3F21
Non Smog - 3F42
$129 + $35 Core
Have them order 4 and look them over good. Pick the 2 best ones.
They are re-worked heads. Some I have gotten had all new valves, seats and guides. Others were a mixture. We have used several pair so far since we discovered they had them at a good price. All have been acceptable.
We always disassemble them, cut in positive valve seals and replace the springs with Crane or Compcams to match the cam being used along with the Crane Pushrod Guide plate Conversion Kit (52655-16). If the valve guides have been replaced then you need to watch the clearance between the seal and retainer.
GoldCo
May 12, 2016 12:19 AM
54Hydro
Nov 8, 2015 10:16 AM
redrock82002
Modular V10 (6.8l)
Jun 11, 2013 06:47 PM
SomeDude451
Jan 29, 2013 10:51 AM
khilding
1978 - 1996 Big Bronco
15
Nov 26, 2008 11:39 PM
