rear main seal; replace rope with rubber.
Old 05-25-2001, 09:26 PM
cntdew's Avatar
cntdew
cntdew is offline
Is there any way to replace the rope seal with a two piece rubber seal with the engine in the truck? After removing the pan and main bearing cap I found the rope seal, to my horror. Can I just pull the rope out and replace it with the rubber seal?
Old 05-25-2001, 11:35 PM
75fef100xlt's Avatar
75fef100xlt
75fef100xlt is offline
Why do want to replace it so bad?
Just don't worry about it man.
Is it leaking or something?
Just forget about it, it is not worth replacing unless you rebuild the engine.
Old 05-25-2001, 11:54 PM
cntdew's Avatar
cntdew
cntdew is offline
Leaked about a quart every tankfull. BTW, got the rope seal out and there was no telltail "locking pin". Makes me happy. Why would the engineers put the pin in the block half anyway, more sense to put it in the cap. Soon I'll have the 2-piece seal in.
Old 05-26-2001, 04:10 AM
karljay's Avatar
karljay
karljay is offline
I've heard that the rear main seal can be replaced without removing the crank. Clean the area and put plenty of oil or grease on the seal. Place the seal on the area where the main cap was then slide it around to the other side. The seal fits in going 1 direction and you'll need plenty of lube. slowly tap the seal around until it's 3/8" out on one side, the put the other side in the cap so that the 3/8" offset matches up. The side seals are tough to get right but extra lube really helps, I've torn a few but go slowly and use mega lube and check for obstruction like dirt, nicks... while cleaning.
Old 05-27-2001, 07:40 AM
otto's Avatar
otto
otto is offline
You dont like those rope seals but they served many a engine and other machine faithfully for a good 60+ years till we came up with rubber, those do leak if installed improperly too, its all in the install, and if installed properly i believe they last longer than any rubber seal
Old 05-27-2001, 11:37 AM
bushman's Avatar
bushman
bushman is offline
ronald48
12-28-2015 06:33 PM
teardropty
08-04-2012 03:28 PM
jarod17
02-03-2011 05:07 PM
stil190
06-03-2007 07:56 PM
jdon88
10-13-2003 10:43 AM
Quick Reply: rear main seal; replace rope with rubber.
