I just bought a 94 F250 with the 460 engine and extended cab. First, is the two door with the back seat referred to as a Super Cab, if not then what? Next and mainly, the lights in the instrument cluster do not all work. What do I have to do to replace the bulbs? Is this a matter of removing the entire dash? is there a way to just pull out the cluster by itself? Any and all help appreciated.
Before you go replacing all your dash lights check your switch. My dash light werent working when I got my truck but I shook the switch and they started. I think the light switch works like a resistor and it may get corroded or worn over time. I hope this helps.
Thank you all for your help. The instruction article is great. Also I will check the switch and maybe replace it. Some of the lights in the cluster work, but about half are off. However, the dome light has constant power which may be as simple as fixing or replacing the light switch. If you have any other ideas, please let me know. Again, thank you for all the help.
