Please help me ID this motor
Old Feb 12, 2006 | 04:12 PM
monmar's Avatar
monmar
Hello Folks, I found a couple sets of numbers on the engine. First set is on the intake (front) 5752033. The second set is down near the starter curb side, C6ME-A.
I was told this was a 428??? Thanks for your help.
Monmar
Old Feb 12, 2006 | 05:57 PM
MBBFord's Avatar
MBBFord
What kind of truck is it in? Or is it even in a truck at all?
Old Feb 12, 2006 | 06:17 PM
monmar's Avatar
monmar
Well its a 1976 High boy, I know its not the original motor and was told it was a 428 out of a T Bird. I mentioned it on this site and was told to get these #s and folks on the site would probably be able to ID the motor.
Old Feb 12, 2006 | 06:32 PM
tjc transport's Avatar
tjc transport
i ain't rite
well by those numbers we can say it is a 1966 mercury engine. thats all though. being that it's a 66, it would be either a 289, or fe series.
C= decade,60's
6= year, 6
M= Mercury
E= Engine
Old Feb 12, 2006 | 06:41 PM
monmar's Avatar
monmar
289?? No, can't be this far to powerfull for a 289, when you say or a fe, do you mean Ford engine and if so??? what? arre there other attributes I can check to confirm if it is a 289 or other??
Tks
Old Feb 12, 2006 | 06:47 PM
havi's Avatar
havi
I'll have the Roast Duck
count the number of valve cover bolts and report back here.
Old Feb 12, 2006 | 06:52 PM
highboy's Avatar
highboy
A 289 is pretty small in size, a 428 is pretty monsterous
Old Feb 12, 2006 | 06:57 PM
MBBFord's Avatar
MBBFord
a fe engine would be a 360, 390, or a 428, and since it was a 76 truck, it was set up for a fe engine and alot of other mods and parts would of been needed to convert it to a different motor, so it is very possible it is a 428.
Old Feb 12, 2006 | 07:17 PM
monmar's Avatar
monmar
There are 5 valve cover bolts per side.. Now what ?? hahahaha
Old Feb 12, 2006 | 07:33 PM
surewhynot's Avatar
surewhynot
I believe that is an FE series, most likely a mercury 410 but I'm not 100% sure.
Old Feb 12, 2006 | 08:13 PM
havi's Avatar
havi
5 valve cover bolts indicate it's an FE motor. 352/360/390/410/428....C6ME is what tjc said. It's a mercury engine and certainly not the original engine in the 76. 360 was typically the stock motor. However yours ain't stock, which the carb would be an indicator of what engine it is. 428's never came with a 2 bbl, but i'm not 100 percent sure on this.
Old Feb 12, 2006 | 08:42 PM
ford390gashog's Avatar
ford390gashog
some mis info in here. the mercury 410 was not a FE. so count that out. second the casting number C6ME-A was not exclusive to merc's. so it does not mean it was installed in a merc at all. the casting number C6ME-A was used until the ealry 70's. only way to get the date is the date code under the oil filter adapter. ford factory installed the C6ME-A block in trucks and cars .
Old Feb 12, 2006 | 08:46 PM
Ford150/428/dud's Avatar
Ford150/428/dud
I have a 428 i could go check the casting numbers.
Old Feb 12, 2006 | 08:48 PM
ford390gashog
if you would that would be great. all the C6ME-A blocks i have here are
1 - 352 4.00 bore
4 - 360/390 4.05 bore
i have never come across a 428. the 428 i did have had no casting number but had a sand scratched C on the back.
surewhynot's Avatar
surewhynot
I'm confused. I have a mercury 410 and the block is pretty much identical to an FE. The c6 tranny off my 360 bolted right up and I'm running a 4bl intake off a 390. I'm not arguing with you. I'm just wondering what a 410 is?
Edit: I mean what the series is considered.
