upper lower ball joints
Old Feb 12, 2006 | 03:29 PM
water 5's Avatar
water 5
Question upper lower ball joints
Did an inspection and the upper lower ball joints are bad need to ask is when this was done did anny other parts you replace wile you have everthing puled apart or need to look for. It 4-weel drive the truck has 135,000 miles iam just trying to get an idea what else to plan for in parts?
Old Feb 12, 2006 | 04:00 PM
surewhynot's Avatar
surewhynot
Might as well check the wheel bearings and grease or replace as needed. Also have a look at the tie rod ends.
Old Feb 12, 2006 | 04:06 PM
Thomasm67's Avatar
Thomasm67
If your wheel bearings are loose inside the front brake rotor then your'll need new rotors i had to have all new rotors and wheel bearings i already put in new lower and upper ball joints along with tie rod ends new drag link and steering arm on my 87 F150 4x4.
