Sponsored by: Real Truck
Manual Locking Hubs
Old Feb 12, 2006 | 01:59 PM
zxreed's Avatar
zxreed
Manual Locking Hubs
I have an 05 F-250 FX4 with manual locking hubs. This is the first truck that i have had with manual locking hubs. What is the max speed you can drive with the hubs locked? Can you leave the hubs locked at all times?
Doug
Old Feb 12, 2006 | 02:24 PM
Beast12's Avatar
Beast12
I believe the fastest they say you can go is around 50MPH when in 4 wheel drive.. I usually don't go over 40. DO NOT drive in 4 wheel drive on dry pavement. In all the plow trucks at work we leave all the hubs locked (transfer case in 2 wheel drive unless plowing) from the first snow fall until the last one. If we have to go on a long trip we unlock them.
You can drive on dry pavement with the hubs locked as long as the transfer case is in 2 wheel drive.
-Matt
Old Feb 12, 2006 | 02:34 PM
zxreed's Avatar
zxreed
Will leaving the hubs locked effect your fuel mileage? Is there a max speed you can drive with just the hubs locked not in 4wd?
Old Feb 12, 2006 | 02:57 PM
Cuda444's Avatar
Cuda444
You'll see an mpg loss driving with the hubs locked. As for max speed, as long as the T-case is in 2x4, you can go as fast as you want. If in 4x4, the max speed is 50.
Tom
Old Feb 12, 2006 | 03:03 PM
Beast12's Avatar
Beast12
Ya, what Tom said. But like I said, if going a long distance and 4 wheel drive is not needed, I will unlock the hubs to take wear and tear off the front end and help MPG.
-Matt
Old Feb 12, 2006 | 05:09 PM
liftmy250's Avatar
liftmy250
why is the max speed 50? is this just recommended, a safe speed for snow, or can the truck not handle any faster?
for some reason my truck handled itself better when i locked the hubs manually as opposed to auto. on the road there was no difference but i'm talkin about parking lots and comin into my driveway, where turning was sharper.
Old Feb 12, 2006 | 05:17 PM
Beast12's Avatar
Beast12
There is no reason to be going faster than 50 MPH in 4 wheel drive. You use 4 wheel drive for traction. If you are going that fast then you obviously have traction, if not then you are driving too fast for the weather conditions. Plus, you start wrecking things when you go faster than that. The front tires are spinning, the back tires are spinning and the truck is trying to keep everything the same speed. You lose your "margin of error" when going that fast. Not good for the transfer case.
-Matt
Old Feb 12, 2006 | 07:37 PM
liftmy250's Avatar
liftmy250
-Matt
makes sense, thanks. i was asking because the other night i was driving home in a snow storm on the interstate....and i had it in 4 because my bed was empty and the rear kept slidin around on the stock POS tires, but i was still on an interstate and had to go faster than 25 mph. i probably averaged about 45 so it wasn't crazy fast....but it was pretty good through 5 inches of snow
Old Feb 13, 2006 | 10:17 AM
bigblu250's Avatar
bigblu250
If 50 is the max speed for driving in 4x4, then why does my owner's maual clearly state I can engage 4x4 up to 55 mph? Not trying to be a smart alec, just curious.
Old Feb 13, 2006 | 10:37 AM
Beast12's Avatar
Beast12
I was guessing it was around 50MPH. I would rather say 50MPH and be under than say 60MPH and be over.
-Matt
P.S. I personally do not go over around 40MPH.
Old Feb 13, 2006 | 10:39 AM
CmprSpecial's Avatar
CmprSpecial
I think beast said around 50... He was close enough for me. Use the owners manuals info, it's supposed to be right.
Personally, I can't imagine any reason to be going 55 with 4x4 engaged YIKES!!
ON EDIT.. I see beast beat me to it. Maybe he had a conversion error when he did the KPH to MPH in his head
Old Feb 15, 2006 | 09:23 PM
bigblu250's Avatar
bigblu250
Thanks fellas, just wondering....don't want to be a smart alec. For the record, I haven't engaged or driven the thing above 45 mph with 4x4 engaged. If I need 4x4 to get somewhere because there's snow flying, I don't travel on the freeway, they are usually clogged with cell-phone drivers and soccer-moms in SUV's. ( Oh crap, there's snow on the ground, time to drive like idiots.. ) Traffic around here can be a real pain.
Alright, alright...enough ranting
Old Feb 16, 2006 | 09:57 AM
SteveH-CO's Avatar
SteveH-CO
The transfer case in a Super Duty has a chain that drives the front output portion of the transfer case. Chains (by nature) have a 'speed limit', by which I mean that they are not suited for extremely high speed use. Gears are better suited for high speeds. Chains will whip and oscillate and do other bad things at high speeds. Ultimately, they will stretch and get noisy when they are significantly worn.
Typically, the 'not over 55 MPH' recommendation has nothing to do with the front axle and everything to do with the transfer case chain.
Steve
Old Feb 16, 2006 | 10:02 AM
fordrose250's Avatar
fordrose250
Soccer Mom
hey....
im a soccer mom....
Old Feb 16, 2006 | 10:40 AM
CmprSpecial
Originally Posted by fordrose250
hey....
im a soccer mom....
We won't hold that against you Besides, you don't drive an SUV..
