is this bushing normal? or damaged?
Old Feb 12, 2006 | 12:20 PM
amm888's Avatar
amm888
00 EB 2x4
hmm, the picture isn't showing, so here's a link
the picture is of a bushing (i believe that's what it's called) attached to the rear axle. i believe the bushing is for the rear sway bar.
the pic just shows the driver's side, but both of mine appear to be cracked, or perhaps that's just how it's supposed to look? can anyone enlighten me here - should i replace them?
i've got a mild creak/squeak in the rear end going over bumps and i'm trying to figure out why.
thanks,
alex
Old Feb 12, 2006 | 02:09 PM
supersonicss's Avatar
supersonicss
Its normal.... Looks like its there to ease in removal and installation.
Old Feb 13, 2006 | 11:56 AM
broncoholic's Avatar
broncoholic
If you're unsure of where the squeak is coming from, or you know that bushing is where it is coming from, just remove it and lube it up with a little white lithium grease between the bushing and sway-bar.
Old Feb 13, 2006 | 05:46 PM
amm888's Avatar
amm888
thanks for the replies guys. yeah, i'm really not sure where the sound is coming from, but i'm guessing it may be the shocks. i assume they're stock, and with 50k on the truck they're prob about ready to go. i was just worried cause the bushings looked odd to me - but i guess they're ok.
thanks,
al
Old Feb 13, 2006 | 07:39 PM
FTE Herman's Avatar
FTE Herman
Looks good to me!
Old Feb 14, 2006 | 12:18 AM
supersonicss
Make sure its coming from the rear of the vehicle... Front ball joints will squeak like crazy when they are going bad
Old Feb 14, 2006 | 12:02 PM
amm888's Avatar
amm888
yeah i believe i've heard the balljoint squeak with my old expy (passed away, sad to say) this noise i'm hearing now is less constant (just over bumps/dips) quieter (can only faintly hear it when the radio is off), lower (more of a creak than a squeak), and really does seem to be coming from the rear.
Old Feb 15, 2006 | 12:42 AM
258exp's Avatar
258exp
It should not take long to lube the bushing by removing the retainer cap, pulling the bushing apart at the spit you have shown and spaying a liberal amount of lithium grease inside. I did so on the front sway bar bushings of an Explorer I owned and it made them quiet again. They remained that way for more than a year. I have since sold the vehicle but was quite pleased with the results on the bushings since it only took 15 minutes or so.
Old Feb 15, 2006 | 12:47 AM
MisterCMK's Avatar
MisterCMK
Replace those shocks mang! The stock Ford shocks are really crappy. You'll be amazed at how nice it is to have new shocks.
Old Feb 15, 2006 | 02:23 AM
ford390gashog's Avatar
ford390gashog
the bushing is fine. but take care when you lube it. make sure to use a grease which does not break down rubber. i simply figured while i had them out i would replace them with poly. www.summitracing.com has them. i then used moly based grease.
Old Feb 15, 2006 | 06:23 PM
amm888's Avatar
amm888
ford390 - all i could find for my truck on that site was a front sway bar bushing set....
mistercmk - what shocks do you recomend?
Old Feb 15, 2006 | 07:23 PM
MisterCMK's Avatar
MisterCMK
I went with Monroe Sensatracs since I got a really good deal on them through my local Napa. I also have those same shocks/struts in my Mustang. They handle nice, ride nice, and are reasonably priced.
