Diesel envy
There isn't anything wrong with the 5.4L....no I wouldn't tow 12k with it....but I live in the Mts. of Colorado and tow 5-7k 6 times per year.....and when I tow I wish I had a diesel...but when I don't tow I am happy. No this truck w/ a 5.4 isn't going to light up the tires or break any land speed records...but it is quite capable of getting you around and towing when you need to.
You said it yourself.....you don't need the diesel, you just want it. If you want it and can afford it, go friggin get it. But don't knock the 5.4 for what doing what it was intended to do....move a truck down the road w/ occassional towing. Mine has been great.....
Ok...bash me.
But I wanted to try a diesel. I drive around 100 a day so i needed something
that would take lots of miles and keep going strong. I choose a a 2000
PSD 7.3 with 130K, because that was the best yr/mileage combo for the amount of money i wanted to spend. ~30K miles later i'm loving every minute. I have a 25mpg car that rarely gets driven.
My trucks get 17-18 on the highway, consider that 18 mpg(PSD) is over 20% better than 14 mpg (V10). Diesel is not 20% higher that gas(20% of $2.00 is 40 cents).
When i was looking I found many 99-2001 with 200-300K miles and all ran great.
I did the tank mod and the HPX less than $100 and WOW, smooth and quite as a v10.
Not knocking the gasser, i've had both chevy and dodge 2500. neither came close to this truck in the Big ,nice truck, feel, ride and sound.
If you have buds/family that likes to hit the road you can't beat the CC for space.
Diesels are not hard to start, they start different, you must wait for a second before you turn the starter.
V10's or V8's. Don't know where people keep getting their info on the gas mileage of the V10, gas hog, but it is usually 1 mile less than the V8 highway or city driving, towing mileage is better than the V8. Plug issue is a none issue, 99 was the problem year. Good luck with the diesel.
As for power, mine doesn't seem underpowered at all. I have no trouble burning the tires (and really burning them, not just a chirp) and it will walk all over my friend's 99 PSD, when both are empty.
I have multiple friends with superduties: there are 6 of us.
4 have the 5.4
1 has the V10
1 has the psd
all are happy with their truck.
Some quick background on me and my driving habits first. I currently have a dying 89 Sierra K1500 with the 350.
I don't tow or plow, nor do I plan to other than maybe towing a uhaul trailer from the northeast to the southwest if we do decide to move. I might throw a motorcycle in the bed or use it to pick up lumber or whatever on Home Depot runs, or the occasional load of firewood. Basically this will be a daily driver. I have a work truck that I take home so I won't be using it for real work or commuting to and from
work either. I'd use the truck mostly just for transportation and weekend travelling.
I'm looking at 4WD 00-03 250 SD's in either standard cab/longbed or supercab/shortbed, manual or auto. The most trouble I'm having here is deciding gas or diesel, and if gas which motor? I had the use of a 2WD 250 SD PSD for a week while visiting relatives in TX and I liked it. From the reading I've done on reviews and forums I think I have some of the pro's and cons for me anyway covered:
Diesel-
Pros:
1. long service life (with proper maintenance)
2. same or better power as V10
3. lots of aftermarket power boosting doodads I ever wanted to go that route.
4. Better fuel mileage than v8 or v10
5. That diesel sound and the sheer grin factor that comes with it when you hit the throttle.
6. resale value
Cons:
1. Diesel costs a few cents more at the pump right now.
2. maintenance costs.
3. cost of parts and repairs (can't just take it to my local mechanic, right?)
4. Problems starting in cold weather?
5. Can I work on these myself?
6. Costs more to buy than an identical truck with a gas motor.
Gas Motors:
Pros:
1. I've had them all my life and understand them.
2. Cheaper to maintain (V8)
3. cheaper to repair (V8)
4. Cost less to buy than a PSD truck
5. can sound nice with relatively inexpensive dual exhaust and quality performance mufflers. (V8) (V10)?
Cons:
1. 5.4 is underpowered relative to the weight and size of a 250 SD. (or so I've readmore than a few times)
2. V10 has the power but is very thirsty.
3. The V10 from what I've read just doesn't sound "right" even with aftermarket exhaust.
4. V10 has to be more expensive to repair
5. I want a diesel.
6. Engine longevity when compared to a diesel
7. The whole popping plugs problem scares me and is something I would rather not have to worry about.
With me, cost is always an important factor. Whether it's initial purchase cost or maintenance/repair/operating costs. I need to get the most bang for my buck. I am leaning towards the PSD because it seems like I can get the same power as the V10 without worrying about popping a plug and while enjoying better fuel economy. Also with the less than average amount of miles I put on my truck per year it should last me quite awhile after I pay it off. Trade in/sale value seems higher than on a gas truck too. Of course I'm factoring in the coolness factor of a PSD (at least for me) over a gas motor a little. =)
On the other hand, if not for the popping plugs the gas motor may make more sense for me. Of couse I'd be hard pressed to opt for the 5.4 given what I've read performance wise, which would leave only the gas hog V10 which I could deal with around town but I'm going to want to get out on the highway on weekend getaways and factoring a big fuel bill into the fun budget doesn't appeal to me.
I've never driven the 5.4 or v10 so I can only go on what I've read here and in consumer review posts I've found. I may well be wrong as far as the 5.4 is concerned, but 260HP doesn't seem like a whole lot considering the weight and size of the vehicle.
I know this is alot to chew on but I'll gladly accept any fact based opinions or experience anyone can offer. See a flaw in my logic? Please let me know.
When the weather clears I'll be test driving all three types of motors before I buy, but I can use any assistance as I need to stop flipflopping between gas/diesel and focus my time on looking for my next new to me truck.
Thanks!
Chris-
I would say get as much input about a Ford truck and go buy one soon
I have never looked back
Anyway, even though I really don't need the PSD, I'm pretty sure I'll end up getting one.
one thing i would like to warn you about though, is that you will get PMS (Powerstroke Mod Syndrome) if you do buy a PSD and hang around here. i bought my truck thinking i would leave it stock except for a leveling kit. $4000 later here i am, and i am about to drop some more money into it. too bad i dont have it yet.
Ditto for me.. I bought the superduty with everything in it thinking there would be nothing else I'd want...
lol...
Shoulda never come to F-T-E y'all are bad influences!!!!
Only gauges and bigger tires so far... But the list is growing!
What I recommend is using Ebay and Carfax. In particular, look for a truck from Texas. I discovered that Texas trucks are cheaper (because there are so many?), and once I found a few I liked, I bought the $30 Carfax subscription (30 days) and ran the numbers. I found my truck (see gallery) for $12K delivered (KBB at the time was $16K). It had 101 thousand miles, and the Carfax report was so detailed, it listed everything, right down to the oil changes perfomed at the dealer every 3000 miles, all the TSB upgrades, etc. There was enough information that I decided to take the gamble (after talking to the Better Business Bureau about the dealer that had the truck). I know that I might have just found a jewel, but I am pretty sure there is plenty of opportunity - just keep looking for what you want, and be willing to wait for it. Good luck!
But also I would suggest a Super Cab or Crew Cab if you take more than one person with you very often. I pick up my kids 6 & 10 from school every chance I get and my little boy is alway bumping my drink holder, not sure how long it will last.
But I dont think you will be disappointed with any choices, as long as you now what to expect mileage wise. Good luck and let us all know what you decide, and show us some pics.
Now that's funny.Cons:
5. I want a diesel.
Chris-
