Sponsored by: Kumho
lift help
Old Feb 11, 2006 | 10:00 PM
fordenator's Avatar
fordenator
lift help
I want to do a straight axle conversion on my 85 f150. I have a 2.5" lift right now but I can't get it lined up at all, anyways I've done lots of seaching on straight axle swaps but everyone is going at least 6" of lift. I like the height of my truck as it is because I haul lots with it so having it to high is just not practical. Do you guys think I could do it with this little lift. I know I will have to make the spring mounts so the ttb springs will work and doing that will give me some height, anyways I have the 79 axle and fabing anything is not a problem but seeing how there are so many people out there doing straight axle swaps I figured I'd ask for some help. Any info would be great.
Old Feb 12, 2006 | 01:42 PM
thesprocket26's Avatar
thesprocket26
Build it for the amount of lift you want. Bigger is better for some people. Maybe not you?
Old Feb 15, 2006 | 08:54 PM
vman's Avatar
vman
I think the minimum you can go is 4 inches.I you look, the crossmember hangs way down so the axle has to be far enough away not to smash it if you bottom out.
