2wd dually rotors?
Originally Posted by JDFARMS
I'm talking about the dust cover that you have to take off to get to the wheel bearing nut on the front rotor hub. The rotor and hub are one piece and the cover is probably 4 or more inches back in the hub.
http://www.matcotools.com/Catalog/to...&page=4슕
EDIT: Go to page 4, it's the last tool on the list.
I think i know what you are talking about. The grease cap is hell to get off. It takes a lot of work and patience to get off without damaging. But the caps are cheap and the easiest way to get off is to punch a hole in the center and hook it with a bent screwdriver or a slidehammer to pull it out.
