General Automotive Discussion
Truck 2-speed
Old Feb 11, 2006 | 11:22 AM
jorlee's Avatar
jorlee
Truck 2-speed
Ford-F 615 single axle that was sometime converted to tandem. Stuck in high range. Checked power and it's doing as supposed to. Would like to know common problems, tips to taking off, etc.
Thanks
Old Feb 11, 2006 | 11:32 AM
DT 466Man's Avatar
DT 466Man
is it possible that the shift motor is stuck?? i know that happened on a couple IH's my neighbor has. Not a bad job to replace.
But his shift motor went out and it was stuck in hi.
Old Feb 11, 2006 | 11:41 AM
jorlee's Avatar
jorlee
Can you just take off the bolts and pullit out? Or, is there a special procedure for removing then installing again? How would you check to see if it is stuck?
Old Feb 11, 2006 | 12:08 PM
DT 466Man's Avatar
DT 466Man
i'm not sure about just removing it......you should be able to, we were.
when you shift from the cab have someone listen for the motor to spin, as it loads a spring and when you let off the throttle and get slack in the driveling the spring pops the shift mechanism and allows it to change ranges.
Old Feb 11, 2006 | 12:13 PM
ReloadX7's Avatar
ReloadX7
Im not sure what year your truck is but in the older two speeds that Ford used there was a two way relay switch located inside and activated by the motor shaft race as it moved up and down . Normally that wears and is what goes out in them but the motor itself comes right off just remove the two nuts that fasten it to the differential housing and unhook the electrical. viola!
Old Feb 11, 2006 | 04:06 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Reload to Ford Truck Enthusiasts!
…..See you on the boards.
