transmision
Old May 31, 2001 | 09:28 AM
BB's Avatar
BB
transmision
Old Jun 1, 2001 | 03:05 PM
RobbieC's Avatar
RobbieC
transmision
I have a 74 f250, It has a granny low four speed with a 390 motor. I was driving it from a stop light in second gear when a loud bang happened and it popped out of gear. the clutch peadle went to the floor so I got it towed home. I just took it apart and nothin was visably wrong with the clutch and pressure plate. I then brought the transmision to the shop and asked him if he can take a look at it. He said he took it a part and there is nothin majorly wrong with it but the gears are warn a little. he said he suggests to replace second gear and the hub asssembly. It would be about 800-900 dollars any sujestings. also what kind of tranny is it. thanks
Old Jun 1, 2001 | 06:30 PM
jowilker's Avatar
jowilker
transmision
For my 2, put in a nice C6 and forget about shifting, but you may be one of those I gotta do it my selfers.
My first thought was a clutch linkage, but your truck might have a cable.
BTW I think you can find a tranny like yours in the recycle yard for much less than $800.00.
John
jowilker
[link:www.ford-trucks.net/users/jowilker|Club FTE since 01 01] My FTE Page
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NC Truck Owners] NC Ford Truck owners group
66F100s Rule
In the cool still quite of night you can hear chevies rusting away.
Old Jun 1, 2001 | 06:39 PM
RobbieC's Avatar
RobbieC
transmision
All the linkage is, is the rod from the pedel to the equalization bar and to the fork. I just replaced the plastic bushings in the eq bar they were pritty worn out. the eq bar was not broken, it was still in tack. how much is a C6, I saw them in PAW for about 900 nad that was a b&m with a shift kit. also if I do put an auto matic will I need to change the stearing colum or can I run the shifter up through the floor pan. I have a 3'' body lift on the truck.
Old Jun 2, 2001 | 12:15 AM
jowilker's Avatar
jowilker
transmision
Robbie the floor shifter is the simplest route. I changed columns when I converted, but I changed to power steering at the same time.
John
jowilker
66F100s Rule
