trans swap ?????
Old Feb 11, 2006 | 06:48 AM
74shane's Avatar
74shane
Talking trans swap ?????
im rebuilding my 79 f150 and want to swap the automatic trans out for a standerd while ive got the motor out. im replacing the 351m with a 460 and dont know witch manual trans will work with my transfer case and bell housing . can any one helpp
Old Feb 11, 2006 | 07:18 AM
User 71024's Avatar
User 71024
If you have an automatic you have the wrong bell housing anyway, and you'd be better off finding a donor truck. your gonna need a bunch of little stuff like pedals, clutch linkage, cross members drive shafts, it gets costly if you try and buy everything individually.
Old Feb 11, 2006 | 12:01 PM
Mil1ion's Avatar
Mil1ion
The C6 attached to that 351M would fit if you were swapping it too, but since the bell-housing is part of the transmission (one piece unit) you will need to find a std transmission behind a 351M/400 or 460 to do the swap.
Old Feb 12, 2006 | 12:59 PM
Jmudder79's Avatar
Jmudder79
Talking
L and L products has complete kits that have everything you need . However they are a bit expensive . I'm doing the same swap in my 79 250 right now and it is alot ceaper to get a donor truck if you can find one.
Old Feb 12, 2006 | 01:04 PM
Jmudder79's Avatar
Jmudder79
Red face
They have ALMOST enerything you will need in the L and L kit. I don't think it has the linkages you will need to swap to a manual trans. I was able to keep my transfer case and just swap it over to the manual. I think you should be able to also. That way you don't have to get new yokes or different u-joints.
Old Feb 12, 2006 | 01:11 PM
Mtthwvn73's Avatar
Mtthwvn73
The transmission that works with the 460 and 351M is a NP435...it won't work with the bellhousing, like EricJ said.
Old Feb 12, 2006 | 11:54 PM
Mil1ion's Avatar
Mil1ion
Maybe read my post #3 again.
The 351M/400/460 all share the same bolt pattern where the transmission attaches to the engine block.
The C6 auto transmission is a ONE Piece unit meaning the bellhousing is part of the case.
So with knowing this info:
Why wouldn't the transmission,clutch,bell-housing attached to a 351M/400 not bolt up to a 460 ?
