Sponsored by: Real Truck
Need Help On Aux Lights
Old Feb 11, 2006 | 04:56 AM
Monster Duty's Avatar
Monster Duty
I'm thinking about running some aux lights . Four Piaa 80 Racing which uses 90/135w H-4 bulbs .
I will also be using two Piaa wiring harness and switches .
I have the factory dual batteries and a single alternator .
Which battery do I hook these light up to ?
Am I going to draw to much current for the stock electrical system to handle ?
How about with 100/150w bulbs ?
TIA
2004 F350 PSD
Old Feb 11, 2006 | 07:22 AM
GarageDoc's Avatar
GarageDoc
From my experince in hooking up winches and 100W two-way radios, the radio and/or lights I would take to one battery. On equipment like the winch pulling heavy current I normaly connect to both batteries.
Your electrical system should certainly handle that wattage.
Old Feb 11, 2006 | 09:01 AM
rwilimo's Avatar
rwilimo
Assuming that this is a deisel, both battery are connected together so it should not matter where you make your connection. After installation, start the truck and check your battery voltage at idle with the lights and everything else on the you typically use, as long as you getting 13 volts or greater (greater would be good) you will be fine.
Old Feb 11, 2006 | 03:42 PM
GarageDoc's Avatar
GarageDoc
High current and hi wattage draws should always be connected directly to the batteries with an independent fuse. Do not just use any 12vdc connection.
Old Feb 12, 2006 | 02:56 AM
Monster Duty
Thanks for the info .
Someone told me that on the diesels one battery was for the accessories and the other was for starting .
The Piaa harness kit comes with all the hardware needed . ie..relays..fuses....
Old Feb 12, 2006 | 09:17 AM
99f350sd's Avatar
99f350sd
Just hook it to the battery thats easiest to get to. There was a change in alt systems but I can't remember what year look in your owners manual it may tell you.
Dick
