C6 pan
Old May 31, 2001 | 10:30 PM
AaronW's Avatar
AaronW
C6 pan
The tranny leaks real bad from the pan, so I figured I should replace the filter fluid and seal. Other than removing that cross member, is there any special trick to it.
Thanks
Aaron
Old Jun 1, 2001 | 10:13 AM
whomrig's Avatar
whomrig
C6 pan
Aaron, the only trick is to not overtighten the pan bolts or the gasket will tear. Sounds like you have the situation well under control so far. I would recommend you get a shop manual and an inch/pound torque wrench for future use though. good luck..
Wayne
e-mail
http://home.pacbell.net/whomrig
Old Jun 1, 2001 | 10:55 AM
beartracks's Avatar
beartracks
C6 pan
When you get the new gasket it will probably be folded up. Set it out the night before on something flat and put some weight on it. If it's cork I spritz it with water first. Then after it's flat you can use sealer to stick it to the pan. Use more weights. After it's dry it's easier to attach it. You might as well get some kitty litter or oil dry as draining gets messy.
Good Luck!
1977 Ford F-100
400m/c6
280,000 miles
Stock on the outside
modified/rebuilt everything
Old Jun 1, 2001 | 11:38 AM
AaronW's Avatar
AaronW
C6 pan
When I drain the trans should I do the torq converter too? BTW, Chiltons will hopefully be here MOnday, that will take care of torq specs and quantities right??
Thanks
Aaron
Old Jun 2, 2001 | 10:05 PM
whomrig's Avatar
whomrig
C6 pan
Aaron, i do recall most fords had a drain plug in the torque converter. it faces front and yes the manual should give you all info you will need.
Wayne
e-mail
Old Jun 2, 2001 | 10:42 PM
fe4ever's Avatar
fe4ever
C6 pan
