Front brake question
Old Feb 11, 2006 | 12:11 AM
77 Fordman's Avatar
77 Fordman
I have a 1976 F-250 parts truck that I was planning on taking the brake caliper brackets off of this weekend. I have never done this before and don't really know what I have to do to get them off, but I assume you have to take the hub, rotor, and spindle off. I was wondering if once I get the brackets off if I can put the front end back together, minus the caliper brackets, and have the truck still be a roller.
Old Feb 11, 2006 | 12:22 AM
ford390gashog's Avatar
ford390gashog
nope. the caliper bracket is part of the king pin assembly. you will have to press them apart. real fun job to say the least.
Old Feb 11, 2006 | 08:38 AM
buzzbait65's Avatar
buzzbait65
assuming it is 2 wheel drive, gashog is correct
Old Feb 11, 2006 | 12:09 PM
77 Fordman's Avatar
77 Fordman
Nope, its 4 wheel drive, maybe I should have put that, it is also a dana 44 front end if that makes a difference.
Old Feb 11, 2006 | 12:41 PM
buzzbait65's Avatar
buzzbait65
just for a rolling axle, you can pull the brackets and bolt the spindles back on, but it is not driveable
Old Feb 11, 2006 | 12:43 PM
77 Fordman's Avatar
77 Fordman
Thats fine, I don't even know if the truck runs.
