Tach or Fuel injector wire
Old Feb 10, 2006 | 10:10 PM
TCELasVegas's Avatar
TCELasVegas
Red face Tach or Fuel injector wire
I have a 03 F-350 crewcab 4x4 dually with a 6.0 diesel. I have just installed a Ford factory keyless entry/starter/alarm unit. I need to know were a may find the tach or injector wire to connect my rev monitor too. If anyone know were to connect this to and the color code of the wire I would greatly appreciate it.
Thank you,
Todd
Old Feb 10, 2006 | 10:45 PM
Mnf350's Avatar
Mnf350
There is a blunt cut light green wire behind the fuse panel that you use for tach signal, I think it has a white tag on it also. Do you have a tach inverter installed? The ford kits I have installed at my dealer raquire a inver.ter
Old Feb 11, 2006 | 11:28 AM
TCELasVegas
Thank you, I will ok for that wire and test it. I didn't read anywere that I need a inverter. I will check with a Ford on Monday
Old Feb 11, 2006 | 12:01 PM
Mnf350's Avatar
Mnf350
I double checked my install instructions and the tach wire is a light green with a white tracer behind the fuse panel and it says on 6.0 engines inverter# 5C3Z-17C304-AA is required.
Old Feb 11, 2006 | 01:31 PM
TCELasVegas
Smile
Thank you Mnf350 you are right and I am going to pick up that part at Ford right now my cost is $16.23.
xlnttech
Aftermarket Products
Apr 1, 2021 10:40 PM
rowdyredneck
Aug 3, 2013 10:45 AM
IDfordguy
Sep 26, 2005 01:00 PM
Big Red
Aug 24, 2005 09:51 PM
bluemustang
Dec 11, 2002 04:25 PM
