You could make it work if you have the time & patience but it is not a simple bolt in swap. The mounts are different for later dashes. As well, windshield curves are different in later trucks. Your 79 cab will also have a piece between the dash and the windshield that is welded (not bolted) that would require removal or modification.
1979 F150 Custom: nothing under the hood at all (again)
1987 F150 XLT Lariat: 88 351W EFI
75 351W: soon to have 91 heads, ?? cam, double roller timing chain, Edelbrock Performer intake & Holley carb and be put back in 79 F150
84 351W: waiting for ???
Chevy 454: waiting for a truck (Mazda?Nissan?)
