gas mileage
Old Feb 10, 2006 | 08:05 AM
Kioke's Avatar
Kioke
gas mileage
What kind of gas mileage can I expect from a 96 F150 with a 4.9/6
long bed with cap.
Thanks
Old Feb 10, 2006 | 09:13 AM
KW160's Avatar
KW160
That depends on whether you have an automatic or manual transmission as well as what gear ratio is in the rear end.
My truck is a 96 with 4.9L I-6, 5-speed manual transmission and 2.73 rear end gear. It will consistantly get 20 mpg on the interstate going 70mph. I think normal mpg from these trucks is between 16-20 mpg.
Old Feb 10, 2006 | 10:11 AM
Kioke's Avatar
Kioke
thanks...mine has a manual trans. I'm not sure about the rear end ratio. 16-20 mpg sounds decent.
Old Feb 10, 2006 | 12:03 PM
nastruk95's Avatar
nastruk95
I have the same set up with the m5od, but with a rear end closer to 3.0 rear end and get an overall average of 18.75 mpg, calculated at quarter, half and full tank averages, and have been doing so for numerous years now. Does anyone know the final drive ratio of the zf transmission to that of the m5od?
