Engine keeps cutting out...
Old Feb 10, 2006 | 07:45 AM
Maxwelk9's Avatar
Maxwelk9
Unhappy Engine keeps cutting out...
My 83 F-250 5.8 has been sporadically missing and sometimes completely dying for no apparent reason (with a loud backfire in the exhaust following the shutdown). I have already replaced the ignition control module and the coil (as well as the wires and connectors on the coil), but it did it to me again this morning. I was only going 10 mph and the truck died, backfired, and then went back to running fine again.
Question: Could a bad tachometer cause this sort of erratic behaviour? I had this same tach wired up in my 88' Dodge Ramcharger before putting it in this truck and I had the same problem with it a few times, but I always figured it was a bad sensor or something since it was fuel injected. The tach always seems to work and even when the truck does die completely and won't start the tach still shows RPM's while you are cranking. Can anyone provide some insight on what may be going on? Thanks in advance for your help!!
Old Feb 10, 2006 | 11:10 AM
Maxwelk9's Avatar
Maxwelk9
Anyone???
Any and all ideas are welcome!
Old Feb 11, 2006 | 01:38 AM
Larry_the_handyman's Avatar
Larry_the_handyman
Sounds like the timing advance on the distributor.
Old Feb 16, 2006 | 12:36 PM
Maxwelk9's Avatar
Maxwelk9
Smile Update on ignition problems...
Well, after cutting the tach wire to my coil I have determined that my tach was INDEED causing all my ignition problems. I have been driving the truck for a week without so much as a single problem now. I don't know exactly what happened to the tach or what caused it to go bad, but the truck is running fine now If only I would have figured this out when the tach was hooked up to my Ramcharger I could have saved myself a LOT of frustration and money. Oh well! At least now I know...
Old Feb 17, 2006 | 12:35 PM
whodat54321's Avatar
whodat54321
a cheap tach may not like the 'direct from the coil' output a ford uses. better to go
indirect by using an MSD box as an isolator if your coil terminal output fried the tach.
Old Feb 17, 2006 | 10:25 PM
Bdox's Avatar
Bdox
Could be an old design tach, meant for points/condenser ignition.
JayFinAZ
19
May 26, 2016 12:45 PM
mgd4me_
Sep 1, 2015 08:30 AM
mgd4me_
Modular V8 (4.6L, 5.4L)
Sep 1, 2015 07:51 AM
dioxippus
May 31, 2015 08:52 PM
mb43
Sep 21, 2004 12:14 PM
