Anyone have an answer for this problem?
Old Feb 10, 2006 | 06:31 AM
gunmetal79's Avatar
gunmetal79
My F250 is registered as a 78 but the only thing that is 78 about it is the body. The chassis is actually a Hiboy F250, between the years 73-77.5. I know this because it has the leaf-sprung Dana 44 HD, old-style ram steering system, and a divorced 205. However, since I can't find the VIN on the frame rails I don't know exactly what year it is. So here's my problem: A few weeks ago I lost a couple of wheel studs when they broke off. I limped it home and spent the better part of an afternoon taking everything apart (lots of annoying problems such as the calipers were put on with an impact gun, the remaining wheel studs were just spinning and had to be welded in place to get a wrench on them, etc. ). Well, I had to get a new 16.5 wheel and rotor because they were trashed from the ride home on six studs. No problem there. But six of the eight holes in my hub assembly also got routed pretty bad out so I have to replace that as well before I can put it back together. Well, finding that particular piece is becoming nearly impossible. Parts stores don't have them and trying to find an eight-lug 70's Ford in a boneyard is next to impossible. I did find a pair on ebay for $159 that includes two hubs and two rotors for years 78-87. Will those work on my 44HD? Everything I've read is contradictory as to which years these axles will interchange between because they switched between 1/2" and 9/16" studs. Also, my hub housing isn't completely round, it is kind of star-shaped (six sided), so I'm hesitant to buy anything round. Anyone have any advice? I need to get this thing running again.....
Old Feb 10, 2006 | 06:44 AM
Torque1st's Avatar
Torque1st
Posting Legend
For axle and hub questions we have a specialized forum.
Your VIN is on the top passenger side of the frame somewhere in the forward half. Usually forward of the firewall but they have been found under the cab. Keep looking for it. Axles may have date and production codes stamped in them.
Old Feb 10, 2006 | 12:00 PM
greenhighboy's Avatar
greenhighboy
The serial number on the frame is on top of the frame rail on the passanger side just ahead of the cab mount. Since it has disc brakes it is probably a 76 or early 77.
Old Feb 10, 2006 | 12:15 PM
gunmetal79's Avatar
gunmetal79
Well, that certainly helps. I didn't know that 76 was the first year for front discs. I'll keep looking for the VIN. Assuming that it is a 76 or 77, what do you suggest about finding the right hub part?
Old Feb 10, 2006 | 06:06 PM
gunmetal79's Avatar
gunmetal79
Old Feb 10, 2006 | 11:23 PM
greenhighboy
I just went out and looked at my truck that has a 76 front axle and the 77 hubs from the original axle and they are round. Are you sure its not a low pinion Dana 60? They were used on76 and 77 four door highboys and had external mounted lockouts.
