1987 v/s 1994 302 engine??
Old Feb 10, 2006 | 06:06 AM
Supercab's Avatar
Supercab
My 302 engine in my 1994 F150 is getting a little worn and am getting started on a replacement.
I have a remanufactured 1987 302 that has about 30k miles on it that I removed from anouther vehicle.
What I am wondering is what the difference is between the two engines internally as I would use all my exterior stuff. Thanks!!
Old Feb 10, 2006 | 08:48 AM
Kemicalburns's Avatar
Kemicalburns
nothing is different. unless your 94 has a roller cam which means the dizzy gear would need swaped out.
Old Feb 12, 2006 | 04:52 PM
Supercab's Avatar
Supercab
OK, Thanks!!!! How do I find out without taking the engine apart IF it has a roller cam or standard cam??
Old Feb 13, 2006 | 09:36 AM
Kemicalburns
pull the lower intake. it should have whats called Dog bones and some other hardware. you could probably go by a stamp on the block some were but im not sure what that would be for a 5.0
